Brake Light Wire Location in Driver Kick Panel?
Hi everyone, just had a super quick installation of a pioneer stereo in my '04 RX330 thanks to all the posts on here. Encountered only one hiccup, could not locate the brake wire by the driver kick panel. I need it to connect to the stereo's reverse wire to start the backup camera whenever I go into reverse. I found some wiring information else where but could not for the life of mine find this green to red wire mentioned:
WIRING INFORMATION - LEXUS / RX 330 / 2005
12volts red (30A), orange (7.5A) + ignition harness
Starter blue + ignition harness
Second Starter white + ignition harness
Ignition purple + ignition harness
Second Ignition green + ignition harness
Third Ignition N/A
Accessory gray + ignition harness
Second Accessory N/A
Keysense black - ignition harness
Notes: Using the status output to trigger this wire during remote start will disarm the factory alarm without unlocking the doors.
Power Lock brown - driver door module in door
Notes: Meter these wires while turning the key in the driver door key cylinder.
Power Unlock gray (double pulse) - driver door module in door
Lock Motor blue to red 5wi driver kick, 20 pin plug
Unlock Motor red to white 5wi driver kick, 20 pin plug
Parking Lights+ lt. green + driver kick, harness to rear
Parking Lights- orange - headlight switch
Hazards purple - hazard switch
Turn Signal(L) black + back of fuse box below BECU
Turn Signal(R) pink + back of fuse box below BECU
Reverse Light green to red + driver kick, gray 20 pin plug
Door Trigger see notes - see notes
Notes: The driver door trigger is blue at the BECU, 16 pin plug, pin 14. The passenger door is blue at the BECU, 28 pin plug, pin 23. The right rear door is gray at the BECU, 16 pin plug, pin 16. The left rear door is black, pin 7, in a 13 pin plug on the right side of the fuse box. Use all four wires and diode isolate each.
The BECU (Body ECU) is attached to the back of the fuse box under the driver side dash.
Dome Supervision lt. blue - R side of fuse box, 12 pin plug
Trunk/Hatch Pin pink or brown - driver kick, gray 20 pin plug
Hood Pin red to black - driver kick, gray 18 pin plug
Trunk/Hatch Release purple - power back door switch on dash
Notes: The fuel lid release is gray (+) at the switch on the dash.
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock use key sense wire
Tachometer white ac ECM, top plug, pin 5
Notes: The ECM (Engine Control Module) is behind the glove box.
Wait to start N/A
Brake Wire gray + brake pedal switch
Parking Brake lt. green - parking brake switch
Horn Trigger white - horn switch
Memory Seat 1 green - memory seat switch in door
Memory Seat 2 purple - memory seat switch in door
Memory Seat 3 N/A -
Immobilizer Bypass Module: Required: Yes Type: Transponder Part #: 556U or 555U
Notes: Standard on all models.
Anyone have any ideas what is meant by green to red? Is it a green/red wire? Would really appreciate it (been researching for days). Thanks!
Third Ignition N/A
Wait to start N/A
Memory Seat 3 N/A -
Thanks! Just did it and it worked like a charm. Getting to the wire was pretty tough since it was in such a tight spot. Alright, onto to the next project.
I realized today that tapping into the brake wire would not be the best idea. Since the backup camera would be activated every single time I stepped on the brakes. ![Egads!](https://www.clublexus.com/forums/images/smilies/pat.gif)
So I decided to take a picture of the other end of the gray 20 pin plug with my phone since it was impossible to view. I found out that the reverse light wire is the furthest left dark green wire, not the light green wire. And the view underneath confirms that it does go from green in the 20 pin plug, and out as red into the receiving wire harness.
I posted some pictures, so hopefully this helps someone out.
ALLWiTE2JZ
02-16-10 08:24 AM
