Anyone have crank pulley holder I can borrow for TB install?
Need it by next Friday.
I will pay for shipping then send back to you.
Something like this:
I am going to try impact gun to remove bolt first, if that doesn't work I will muscle it.
![Wiggle](https://www.clublexus.com/forums/images/smilies/wiggle.gif)
How about building one.
3" wide iron/steel 2-3ft long
1.5" (for the socket to get through) drill
3/16" drill
2 bolts
Plans are some where in first gen RX.
Salim
3/16" drill
2 bolts
Salim
Is this what you are looking for?
https://www.clublexus.com/forums/rx-...ghtmare-2.html
Was right here at 2nd Generation RX.
I used an impact wrench a few times. One time I used a long breaker bar and used the starter to loosen the bolt by quickly turning it over without starting engine. Both methods worked fine for me. You can you tube the breaker bar procedure.
I made one of these and with just a breaker bar was able to remove the crank bolt. I had tried the impact, but it just wasn't making it. with the holder tool it was a snap.
I doubt very seriously you gonna get it off with an impact. We tried with a big gun from the local tire shop & a 200 psi compressor & it didn't budge. We ended up making up a holder from a piece of flat stock. Cut a v in it to clear socket & 2 holes for the bolts to screw in to pulley. Used breaker bar then impact to run it out & holder worked as a puller as the bolt came out.
https://www.clublexus.com/forums/rx-...iy-w-pics.html
speedemon
Northeast
06-23-09 10:22 AM
TMaxxTim
Performance & Maintenance
07-12-05 09:46 PM
