2004 luggage/cargo net
Old 04-01-14, 04:22 PM
RX3302004
RX3302004's Avatar
Default 2004 luggage/cargo net
My vehicle didn't come with 1. When I look at the black clips in the rear of the RX, it seems the net would lay down and cover an object rather than going across the back say taillight to taillight. But I see the nets advertised at Sewell and elsewhere as going across the back.
If you have this model, how does your net fit? Thanks.
Old 06-13-14, 01:31 PM
RX3302004
RX3302004's Avatar
I bought an original net from a dealer, and it comes with a paper template that you put on either side basically inside the rear taillights. You drill a hole into the hard plastic, then there are bolts that you screw into that hole, 1 on each side. These bolts come with a T clip that you hook the net onto, in addition to the clips that are on the bottom installed with the RX.
Old 06-18-14, 07:55 PM
LeUsX
LeUsX's Avatar
I was thinking about purchasing a cargo net too but was hesitant when I heard it required drilling. Can you post pics of the final look?
YODAONE
02-19-18 08:35 PM
CPMD
01-17-12 08:25 AM
drivenicel
12-26-09 07:42 AM
Quick Reply: 2004 luggage/cargo net
