OBDII Phone Apps
Old 05-02-14, 01:10 PM
Nozzleman
Nozzleman's Avatar
Default OBDII Phone Apps
Has anyone tried any OBDII phone apps? I assume that you would need an adapter/interface cable too. Which ones are favored?
Old 05-02-14, 01:46 PM
hypervish
hypervish's Avatar
ELM 327, bluetooth if you have an Android device and WiFI if you have iOS.
Old 05-02-14, 02:26 PM
RX330inFL
RX330inFL's Avatar
Android apps are better, IMO. Carista is a supporting vendor here at CL for your software needs.
Old 05-04-14, 12:06 AM
JProdun
JProdun's Avatar
I'm using Dash Command. Pretty satisfied, though used this one, so can't compare.
Old 05-04-14, 12:07 AM
JProdun
JProdun's Avatar
Oh, and yes ELM327
Old 05-04-14, 12:22 AM
RX330iPad
RX330iPad's Avatar
Old 05-04-14, 12:57 AM
spacecraft
spacecraft's Avatar
+1. It works nicely on my Android phone connected with the ELM327 bluetooth adapter.
And it's good to have the rev counter, which is otherwise missing on the 400h.
But I found that some parameters which in theory the app can handle (like for instance the engine load and the oil temperature - both for engine and transmission) are not displayed. Did anyone else experience that?
Old 05-09-14, 04:25 AM
iplexman
iplexman's Avatar
my elm327 can't connect to ecu. who can help me to fix this problem.
Old 05-09-14, 05:09 AM
Mudbug
Mudbug's Avatar
I'll try this myself with my Sony Z1.
Old 05-09-14, 08:53 AM
1koolfella
1koolfella's Avatar
Will the OBDII let you know which tire is low, instead of having to check each one to see if it's under pressure.
Old 05-09-14, 09:18 AM
RX330inFL
RX330inFL's Avatar
No, not enough information is transmitted by the sensors even on the newer versions in the RX with proper TPMS.
Old 05-09-14, 09:28 AM
RX330inFL
RX330inFL's Avatar
Does your vehicle support OBDII? Depending on the market there are other diagnostics used. For example, the EU has its own vehicle diagnostics requirements. If your vehicle does not support OBDII and your ELM327 device only supports OBDII, then they will not talk with each other.
popping
12-13-15 02:52 PM
Mhobizal
ES - 6th Gen (2013-2018)
13
08-03-14 10:39 PM
skxm5
07-05-12 09:55 AM
KuyaPatz
05-09-06 11:58 PM
Quick Reply: OBDII Phone Apps
