Replacing rear bumper corner reflector
Old 07-15-09, 03:39 PM
2006rx330
2006rx330's Avatar
Default How to change the rear bumper reflective lense?
I recently got into a small accident, where another car hit my rear passenger side bumper and cracked the rear bumper red reflective corner lense. I attempted to take the cracked lense off but i only found one bolt bolting the lense down to the bumper.
I was unable to take off the lense even with the bolt off and it seemed like there was not enough room in the bumper to take the lense off.
It seems like i may have to take off the entire rear bumper to replace my lense but before i do this is there a way to take off the lense without taking off the bumper? I dont understand wy lexus would make it difficult to change a lense off the rx330, especially a reflective lense.
also could anyone recommend a website that may sell cheap passenger side rear bumper reflector lenses, or even a site that sells clear rear bumper reflective lenses *if there are any for the rx330).
thanks for your help
Old 07-16-09, 03:08 AM
arnieosp
arnieosp's Avatar
I replaced mine about a year ago after my son cracked it. I was able to wrestle it out without removing the bumper. It was tight but doable. I bought my lense from the dealer, it was around $80, if I remember correctly.
lex2004mm (06-11-18)
Old 07-16-09, 06:51 AM
mandyfig
mandyfig's Avatar
You can try fleabay too. I am sure they sell them.
Old 04-16-10, 09:38 PM
wootw00t
wootw00t's Avatar
Default Replacing rear bumper corner reflector
I have a cracked reflector and got a quote few months ago from the dealership about replacing this reflector piece and they wanted over $200+labor.
I was wondering does it require the bumper to be removed to replace it? If it's easy I want to buy it online from US and then install it myself.
Thanks.
Old 04-16-10, 10:06 PM
Nad1370
Nad1370's Avatar
From the looks of it, the bumper needs to come off.
I think it is screwed in from inside the bumper.
Old 04-16-10, 10:48 PM
pauljcl
pauljcl's Avatar
Thanks.
The bumper has lots of clearance space from below. I bet that, if you lie down and look up under the bumper, you will see the reflector and any screws or bolts or nuts holding it, if such exist. It's worth a try...
Old 04-21-10, 04:19 PM
arnieosp
arnieosp's Avatar
I did it on my wife's car, no cover removal needed. I bought the light assembly online for around $80. Took me 10 min to replace. Do some search, this subject has beed discussed few times.
Old 05-09-14, 11:40 AM
torresr52
torresr52's Avatar
Default RX350 Rear Bumper Reflector Installation?
Do I need to remove the rear bumper to replace the rear bumper reflector?
Old 05-11-14, 06:57 AM
lex_rx
lex_rx's Avatar
I replaced a rear reflector bulb which was easy to do but I didn't notice how the reflector assembly itself was attached to the bumper.
Old 05-13-14, 02:18 PM
jakenbake
jakenbake's Avatar
Yes...The bumper has to come off to replace the reflector. There isn't enough room with the bumper on to pull the reflector out with the bumper on. It sounds much harder than it actually is...If you are at all handy, it is pretty easy.
Old 05-13-14, 04:43 PM
dadcat1
dadcat1's Avatar
I replaced the reflector on a neighbors 2004 RX330 without removing the bumper. IIRC, I did have to remove one clip for the bumper cover to get the needed clearance for removal of the reflector.
Old 05-14-14, 08:19 AM
mandyfig
mandyfig's Avatar
This is the right approach. Be careful in not bending the bumper too much.
Old 10-08-14, 02:43 PM
StkMkt
StkMkt's Avatar
My rear bumper reflector broke and I have to replace it. I have not done this before. Is there any work instructions/video available?
Please advise.
Thanks!
Old 10-08-14, 07:02 PM
LSBen
LSBen's Avatar
Can you share where the clip is located that needs tobe removed and if any bumper screws needs to be removed. I also have a cracked reflector to replace. I also bought a reflector from EBay but haven't figured out how to install
Old 10-08-14, 08:43 PM
LSBen
LSBen's Avatar
I found the link with instructions.
https://www.clublexus.com/forums/rx-...install-2.html
Quick Reply: Replacing rear bumper corner reflector
