2007 RX350- What Tire Pressure for 18 inch rims ?
Old 07-16-14, 07:24 PM
Gs300Rus
Gs300Rus's Avatar
Default 2007 RX350- What Tire Pressure for 18 inch rims ?
I got rx350 with stock OEM 18 inch rims.
Today I bought Micheline Premier A/S.( all season tires).
What tire pressure should I maintain ?
I know manufacturer recommends 30 psi, but that is just for 17 inch.
Advices are highly appreciates.
Cheers.
Old 07-16-14, 08:27 PM
ho0n
ho0n's Avatar
Lexus has 35 psi on the sticker for 18 inches, but I like to go halfway between that and the tire's listed load. It means I'll still be matching spec if any tires are running "low."
Old 07-16-14, 08:36 PM
pauljcl
pauljcl's Avatar
I have 18" rims and the recommendation is 30psi. I run 31-32psi.
Old 07-17-14, 05:24 AM
alchemist
alchemist's Avatar
this right here.
Old 07-17-14, 06:35 AM
ho0n
ho0n's Avatar
My mistake! It's been a long time since I went by the sticker.
Old 07-17-14, 07:27 AM
Gs300Rus
Gs300Rus's Avatar
I thought 30 pst is only for 17 inch rims as they are STOCK option.
What tire pressure to keep in summer? as usually it expands when its hot.
Old 07-17-14, 08:21 AM
takeshi74
takeshi74's Avatar
If you don't have your manual or sticker you can always refer to the documentation on the Lexus Drivers site.
Link to specifications for the 2007 RX350:
http://drivers.lexus.com/t3Portal/do.../sec_06-01.pdf
Old 07-17-14, 12:04 PM
pauljcl
pauljcl's Avatar
Keep the same pressure. Just check your tires because, as you state, the pressure will increase when the temperature rises and you need to re-adjust. Similarly, in winter, you will need to add air to maintain the pressure, if the temperature differential between summer and winter is great.
Old 07-18-14, 05:10 AM
smassey321
smassey321's Avatar
31 - 32 is perfect for comfort and tire wear. When I load up for road trips I go to 35 but I don't leave it there as it wears the center of the tire faster than the edge. I have an awd 400h which is heavier than the other RX models.
Tire wear also depends on the tire model. The Michelin Energy has a soft edge so I could run at 34 all the time with those and the tire wore evenly. My current Michelin Latitude has a harder edge and they are wearing evenly at 32 psi.
Old 07-18-14, 10:43 AM
ho0n
ho0n's Avatar
To my knowledge, most tires today are radial steel-belted, so higher air pressure should not result in the bulging of the center. If this is the case and your tires are aligned and regularly rotated, wear should be even-steven as long as you maintain pressure close to or reasonably above vehicle spec.
Old 07-20-14, 10:04 PM
satz
satz's Avatar
I use 38 to 40psi (when the tire is hot). In the attempt of making my RX 350 handle a little better....and more economically
Old 07-20-14, 10:07 PM
pauljcl
pauljcl's Avatar
... but what a terrible ride!
Old 07-30-14, 11:42 AM
YWW
YWW's Avatar
Arrow
Cheers.
30psi is the factory spec for 18-inch. I set mine to 32psi because 30 seems to wear a bit more on the outer edges of the tire. If it rides a bit firm for 32, then just back off to 31.
How do you like the Michelin Premier A/S so far? I thought about getting that last week but local Costco didn't have that in stock so I went with the same Michelin MXV4 I had before.
Vibes63
05-16-12 04:06 PM
orateam
HS 250h Model (2010-2012)
12
03-19-11 07:39 AM
mlymburner
07-29-08 12:33 PM
martini3
07-07-08 08:17 AM
ChuH
Wheels, Tires & Brakes Forum
06-20-01 01:39 PM
Quick Reply: 2007 RX350- What Tire Pressure for 18 inch rims ?
