overhead USB installation
Hi gang,
Looking to install a DC 12v to 5v convertor to provide power to either a dash cam or GPS. Where the best place to tap into to get 12v? Mirror or sunroof or map lights? Looking for a clean install and any wiring instruction pin outs or how to disassemble the moldings required to access the wiring appreciated.
This is for 400h if anything dissimilar to other models.
the best way to get the cleanest and safest power, is to get Add-a-fuse/fuse tap that you plug into the fuse box and then you can run the wires up the side pillars to the headliner.
I just did this for a dash cam. I gave up finding switched power after poking around for 30 minutes. I ran a wire down the A pillar in 5 minutes and spliced into the back of the cigarette lighter. The gasket pulls away and makes it easy to tuck a wire behind the trim. Remove a screw on the visor clip and the headliner pulls down easily. I removed the overhead console and put the converter box up there. Then ran the USB wire down the rain sensor so it is nice and hidden.
Tap a fuse may be a little easier as long as they sell the right tap a fuse for our tiny fuses. There also needs to be room for the fusebox cover go back on.
I probed every single wire in there and only found constant power. Remember the sunroof will operate for a few minutes after the car is shut off. Homelink and visor mirrors are also constant. The auto dimming mirror could work but I gave up at that point.
