driver rear window
Old 08-06-14, 09:48 PM
iyaoyas247
iyaoyas247's Avatar
Default driver rear window
just did timing belt and driver rear window wont go up. light flashing at switch. rest all others nogo on this one. disconnect battery and try again ?
Old 08-06-14, 10:14 PM
jakenbake
jakenbake's Avatar
If the light is flashing, that window probably didn't get reset after they reconnected the battery. You have to roll it up from that window (not from the master switch) and then hold it for an additional second. Then it should go back to normal.
Old 08-07-14, 04:29 AM
iyaoyas247
iyaoyas247's Avatar
Default diver side rear window
no good at window switch or drivers. no movement at all. flashing light gives me hope though.
Old 08-07-14, 05:21 AM
iyaoyas247
iyaoyas247's Avatar
pulled switch noticed all tabs broken after professional body shop repaired door few years ago. zip tied it together reset procedure. all good now except for auto up at switch . driver control auto up and down good. great forum thank you to those who keep it running
LS2k
06-25-23 06:59 AM
ccarruth
06-04-19 03:58 PM
Rsbaker
04-11-15 10:47 AM
Wierdazndu
05-05-09 10:10 AM
wickedfn4u
12-05-07 10:36 AM
Quick Reply: driver rear window
