CD Player Error 4
Gave up on FIXING MULTI CHANGER
sAll my research about multi CD Changers in ANY car says they are at best unreliable overall. I replaced the changer in my 2005 RX330 and 3 years later hit quit completely. The instruction on unloading a broken changer worked for me
BUT after checking into replacements a third time, I decided it was more cost effective to go to aftermarket and upgrade my system with a new radio with XM capability, single CD player, I-pod capability, USB port, AUX port and back up camera. All this for about the same as getting my Multi changer repaired.
Lets hope this lasts as long as I have the car
the WAV Files will be on average 45- 50 MBs therefore usually around 14-15 songs per music CD.
I unplugged the battery and that didn't work so I started to take the stereo out of the dash to take it apart. Before I unplugged the harnesses from the back, I noticed the label that tells you how to put the stereo in "shipping mode". With the car off, hold down "seek up" and "disc" at the same time. Continue to hold the buttons and turn the car to "ACC" mode. This immediately ejected the CDs and the word " SHIP" displayed on the screen. I pressed "LOAD" and that took it out of shipping mode and everything is working like normal.
Thanks! It worked perfectly !
It doesn't work in my 2006 RX400h
CD Changer in RX330 Lexus 2005 shows error 4
I HAVE TRIED THE INSTRUCTION YOU GAVE ON YOUR POST IS NOT WORKING SO I WAS WONDERING IF MAYBE THERE IS SPECIFIC TIME LIMIT I NEED TO HOLD THE BUTTONS BEFORE THE SHIP MODE WILL COME UP OR SOMETHING ELSE PLEASE ADVISE THANK YOU .
MY CD Changer in RX330 Lexus 2005 shows error 4
Cd stuck
This technique has worked for my 2007 RX350 as well and I’ve had it since January 2021. The first time it happened I didn’t know what was going on second time I got pissed, third time I stayed broke so long til I forgot about it. All three times it started back working on its own. I didn’t do anything. THIS LAST TIME IT GOT STUCK which was today I was fed up at this point. So I went to the internet typed in what I saw on the screen this forum popped up strolled down saw the quick fix instructions and BAM PROBLEM SOLVED! Only one CD was stuck so now I know how to fix my ERROR 4 problem!!!
thanks smart guy!!!
Again
jnstructions are (Make sure truck is OFF)
1: HOLD SEEK UP AND DISC AT THE SAME TIME
2. TURN ON SWITCH AND HIT EJECT
THIS SHOULD BRING ALL CDS OUT
IF NOT IM SORRY BUT YOURS JUST MAYBE BROKEN
thanks smart guy!!!
Again
SJM (07-31-23)
I had the same issue and it would work temporarily. A funny thing happen. My driver visor was lose and was driving me crazy. Also my right rear window was not opening. I replaced my driver and passenger visor as they came in a set. At first I didn't notice it but I was switching between CDs and skipping tracks and all of a sudden my rear right window now also opens.
I guess all three were on the circuit.
Won't start after fixing stuck CDs..
Edit!
Nov.3'23
Please HELP!
After doing this hack early this morning, my alarm went off abt an hour later. Battery was obvi dying bc it was very slow and quiet. Car wouldn't start. Which has happened before, tbh and is annoying!
Just tried starting it again and DEF won't start. Says to put it in PARK (it is) and CHECK VSC (?).. Won't turn to READY.
What kind of hack do I need NOW? I've had it for 2y, has approx 124k miles, and have had so many tech issues w it not starting or being locked out.
The regular battery is prob temp "dead" I'm assuming, I have a portable charger, but ofcrse now it's pouring rain.
9 Years after your post and this saved my sanity today.. Thank you! It worked on my '06 RX400h!
Nov.3'23
Please HELP!
Last edited by Strlsn; 11-03-23 at 04:31 PM. Reason: Car won't start after doing this hack!
Edit!
Nov.3'23
Please HELP!
Nov.3'23
Please HELP!
PS: Don't forget to reset windows and moonroof.
If 12v battery was disconnected, then
https://www.clublexus.com/forums/rx-...l#post11028448
PS: oops
I've read it as "changed". sorry...
PS: oops
Strlsn (11-06-23)
