I am having the same issue with my 2010 rav4, please can someone explain what this solution is. Just file down the sensor where it touches the knuckle???
You know you could have called me and i would have walked you through everything you mentioned above in 10min
J/k
I have a question about a speed sensor issue on my GS350. I’m curious you have any ideas.
i had a bad left rear hub bearing. I replaced the hub assembly and broke the speed sensor in the process. I start the car and get “ brake malfunction, check abs , check BSM, BRAKE light and trac control off.
I purchase and replaced the speed sensor. I start it and thank goodness, all the lights are off. I drive to a family member’s house and after 25 minutes all the same lights come back on.
do you have any ideas? Do I need to disconnect the battery to reset? Do I need to have someone scan and reset codes or something else?
