#3 cylinder code of P0303
I replaced a front bank coil a couple of years ago and now my daughter tells me that the Autozone scan shows P0303, or #3 cylinder misfire. I have searched here and apparently the rear bank is a PITA to get to. Has anyone done this that either has advice or photos? Can this be done without taking the intake off?
Any hints?
Thanks in advance.
grumpa72
grumpa72@gmail.com
yes, still searching the forum using variations of the phrasing.
Any hints?
Thanks in advance.
grumpa72
grumpa72@gmail.com
I found the DIY about two hours after posting by looking up spark plugs instead of coil pack. Nice write-up. Btw, what was the time to complete this task? I have a local Toyota dealer who will gladly do Lexus work and I don't know if my back will allow me to work on that rear bank. I am thinking of asking the service manager "how much to do the rear bank of plugs and coil packs" and I supply the parts.
- Plan for 6 hours. I worked on Friday night (tear down). Buildup (Sat morning).
- If you have disc issues on S1, L5 or L4 vertebrae I would advise against this task. Lots of leaning over.
- Usually Lexus charges 800 bucks for the job. Toyota will be less.
- The parts are not the costly factor but the labor. Spark plugs are $5 each and one coil is $50.
- Most dealer service depts wont allow you to bring your own parts because of 'liability'
A couple points here:
So, from your write-up it is impossible to replace a coil pack without taking half the engine apart.
first things first
clear the code and see if it comes back. the chance is slim, but it could be a one time event.
secondly, it might take a few weeks or more to come back, assuming it does, this will at least buy you some time to research it.
worst case. it comes back right away.
first things first
