2008 rx350 TMPS light on
Old 09-30-14, 02:51 PM
kknguyen11
kknguyen11's Avatar
Default 2008 rx350 TMPS light on
hi all
I just got my TMPS light on this morning, check pressure all 4 tires are good, 35 PSI each, did not check spare tire, does spare tire had TMPS sensor? what do you think? is one of my sensor is bad?
V/r
Khoi Nguyen
Old 09-30-14, 02:55 PM
beefmc
beefmc's Avatar
Yep spare tire does have one that communicates with the car. I just had to replace a bad sensor on my 07
Old 09-30-14, 04:46 PM
kickin8
2IS/2RX/4RX
kickin8's Avatar
yes...usually the spare pressure is low....
Old 09-30-14, 08:07 PM
takeshi74
takeshi74's Avatar
Yup -- check the spare. Been there, done that.
Old 09-30-14, 08:55 PM
Rainbird
Rainbird's Avatar
To avoid the TMPS light I always inflate the the spare to 38psi. I don't run on that tire anyway and at that pressure no warning lights.
Old 10-01-14, 04:16 AM
wzwz8221
10th Gear
wzwz8221's Avatar
If the light is still on after you confirm the spare tire pressure is fine, you may have a bad sensor. if you are Costco member, costco tire center can check and replace the sensor for a price of $15 + the cost of the sensor, which is around $50 to $70. If you go to a dealer, the sensor alone is about $150.
Ironman50
12-10-14 05:30 AM
Barry1
GX - 1st Gen (2003-2009)
10-17-11 11:56 AM
Senin
07-26-11 12:50 PM
SACrx350
02-23-10 12:20 PM
pseconds
ES - 5th Gen (2007-2012)
02-20-10 03:52 PM
Quick Reply: 2008 rx350 TMPS light on
