Hey guys, I have a question concerning the DRL replacement bulbs.
At first, I thought my DRL's went out on the passenger side, so I was just going to buy a set of HID DRL conversion kit from: http://store.ijdmtoy.com/9005-LED-Da...X-p/90-001.htm
Upon closer look, it seems like only the small bulb above the halogens went out.
I tried looking for past threads, but couldn't come up with any results.
Hoping someone can guide me to right direction?
Thanks in advance for the help!
It's a 168 bulb. Small wedge base. A 194 will fit too, but the base on the 194 is slightly wider than the 168, so you would have to break some of plastic on the connector to make a 194 fit.
Be sure to use the correct bulb. There are several bulbs that size but they each have different wattages. The extra heat makes the bulb socket brittle.
^what jakenbake said. Unless you go LED. Pulling more than a circuit was intended for is never really a good idea.
Edit: Spelling (face palm)
I just replaced both if mine with LEDs. Much brighter, but it sounds like you're saying wattage shouldn't be a concern because its LED and its not as hot so I can rest easy??
