2009RX-350 AWD,90K..radio antenna
Old 11-12-14, 01:52 PM
ajay60610
ajay60610's Avatar
Default 2009RX-350 AWD,90K..radio antenna
Garage door didn't open all the way so when i drove into garage i cracked the base of the antenna that sits on the right side of the roof[for some reason it was in the up position].....not sure if this damage will affect radio reception....long screw- in part of antenna is okay but the base and ball socket are cracked....new antenna device $550+[parts and labor] quoted from dealer....so far reception seems okay[damage happened yesterday].....wondering if reception will get worse and eventually die...any suggestions would be appreciated....thanks.
Old 11-12-14, 01:58 PM
jakenbake
jakenbake's Avatar
$273 for the new antenna and install it yourself. It is just held on with one nut between the roof and the headliner. Should be really easy for a do-it-yourselfer.
http://www.trademotion.com/parts/200...&siteid=214915
Old 11-12-14, 04:33 PM
ajay60610
ajay60610's Avatar
Thanks Jakenbake...the dealer said it would take a total of 2 hours labor@$140/hr.
Old 11-12-14, 08:17 PM
Carver
Carver's Avatar
You might consider a fin replacement, runs about 100 plus paint. If the antenna wire with the eyelet is accessible it can be attached to the fin. I've had mine for a couple of years with no difficulties. Click th fin link in my sig for more information.
Old 11-13-14, 04:31 AM
ajay60610
ajay60610's Avatar
Carver,
Not able to find fin link as you noted in your email to me....please send me the link on another post as your schedule permits...thanks for your help.
Should i purchase the fin from the lexus dealer?
Old 11-13-14, 07:32 AM
Rainbird
Rainbird's Avatar
Here is the CL Forum link:
https://www.clublexus.com/forums/rx-...shark-fin.html
myonoshane
04-15-15 09:33 AM
Moose329
12-14-14 10:07 PM
fraguada1
10-05-11 04:05 PM
bod1287
IS - 1st Gen (2001-2005)
03-28-11 03:20 PM
froboy272
10-10-08 09:37 PM
Quick Reply: 2009RX-350 AWD,90K..radio antenna
