interior lights dont turn off
Old 11-17-14, 07:51 PM
tubenut96
tubenut96's Avatar
Default interior lights dont turn off
The dome lights on my 2008 RX400H wont turn off when doors are closed. Door ajar light goes out but dome lights stay on. Anyone else has this issue?
Old 11-17-14, 09:11 PM
pauljcl
pauljcl's Avatar
The dome light switch, I believe, has three positions. One is for always 'off', second is for 'on' when door is open and 'off' when door is closed, and the third is always 'on'. Check its position....
Old 11-18-14, 12:15 PM
kickin8
2IS/2RX/4RX
kickin8's Avatar
And there are map lights as well....
Old 11-19-14, 05:40 AM
tubenut96
tubenut96's Avatar
I did check the switch position and all set to "door" . I have turned the switch to off so that the battery doesn't run down but the door sills stay illuminated. I suspected a faulty door jam switch but why would the door ajar light go out and not the dome lights when the door is closed. Maybe something wrong in the dimming programming.
Old 11-19-14, 07:39 AM
pauljcl
pauljcl's Avatar
Very strange. Let us know what Lexus/Toyota say.... Good luck!
Old 11-19-14, 12:36 PM
jakenbake
jakenbake's Avatar
You are waiting the 30 seconds for them to turn off, right?
Old 11-23-14, 05:52 AM
tubenut96
tubenut96's Avatar
I guess it off to the Lexus dealer. I will post the resolution
Old 10-30-17, 09:22 PM
scottrude
scottrude's Avatar
what did you find out?
Old 11-01-17, 08:58 AM
bwhitsonjr
bwhitsonjr's Avatar
Ditto... Inquiring minds want to know!
Old 10-29-20, 09:02 PM
Dan58
Dan58's Avatar
what is the fix, I have the same problems
Old 10-29-20, 09:05 PM
Dan58
Dan58's Avatar
What is the fix please I have the same problems
Old 11-01-20, 01:25 AM
Margate330
Margate330's Avatar
When you are sitting in the car with doors closed and car running does your dash cluster show any doors are open?
Old 11-01-20, 11:09 AM
Dan58
Dan58's Avatar
I all ready tried that. Nothing on my dash cluster. The dome light and the light on the sills stay on. Please anyone with solutions help.
Old 11-01-20, 12:04 PM
Margate330
Margate330's Avatar
Here is some detail on this- I put in some notes that should help move forward with the diagnostic.
Hopefully an easy fix.
PS- this is for overhead light- if overhead light goes off properly when set to "door/auto" it can suggest the body ecu is working properly.
Also, if the "dome light" you are referring to is the light on the ceiling over the back seats that is a different wiring detail.
Old 11-01-20, 01:48 PM
Margate330
Margate330's Avatar
For anyone going thru this there is quite a bit to the interior wiring.
The problem is the Body ECU manipulates the ground wire for the interior lighting circuits. Many of the lamp's ground wires are spliced into the same common ground wire so if there is a short to frame ground in any in the ground wires in any of the lamps in question it will bypass the body ECU and keep all lights lit in the circuit.
How I would start:
Step 1: Confirm Body ECU recognizes all doors closed by info in dash cluster.
Step 2: Verify front overhead light and/or rear overhead light turn off/on properly when door closed/opened and if not see if position switch isn't shorted by manually turning lights on/off thus confirming a failed switch isn't completing the ground for all other lights in the circuit.
Step 3: List all lights that are failing to turn off,
Step 4: Attempt to figure out which component/wire/junction is shorting to frame ground and keeping all lights lit in affected circuit.
Hopefully this can be done without tearing out the interior chasing wires but would be helpful to know if any of the interior lights are turning off properly when doors are closed and narrow it down. Bad Body ECU with interior light circuit failure is another possibilty I should add.
Quick Reply: interior lights dont turn off
