Possible Overheating issue
I noticed about a month ago everytime after my RX idles for a while I hear something come in like a fan then it turns off. Well today I noticed after sitting in traffic that my gauge for the temperature was going up, once I drove the needle came back down. My coolant level is good, could this be a leak?
Sounds like the cooling fan sensor.
There is an easy way on how test the radiator fan itself. Simply turn on the A/C to the coldest temperature, the cooling fan should come on immediately. If the fan fails to operate you have a bad cooling fan. If the fan turns on the cooling fan sensor is the culprit.
