rx 330 rear hatch won't open
Old 01-03-15, 02:53 PM
durf23112
durf23112's Avatar
Cool rx 330 rear hatch won't open
Disconnected battery and allthe switches in the dash, including on/off in glove box. So that's what caused the problem. Now to fix it. I re-connected battery and all switches, bit hatch won't open with key switch or any switches in car (at door or in front dash). I did manual open and close without any result., the button in glove box is pushed in. help!!
Old 01-03-15, 03:55 PM
jakenbake
jakenbake's Avatar
After disconnecting the power, you are supposed to open the door manually then close it with the button on the door. This resets the motor.
Old 01-04-15, 07:30 AM
durf23112
durf23112's Avatar
I have unlocaked all doors and opened and closed the rear hatch manually. Nothing.
I tried doing what you said and opened door manually then hit the black button on the door to close it. Nothing.
Any other suggestions
Old 01-04-15, 10:30 AM
jakenbake
jakenbake's Avatar
Hmm...I would double check the glove box switch and make sure it is connected to the wire harness and also check the fuses. But other than that, I am at a loss.
eisens
10-01-19 03:37 PM
Luap
RX - 3rd Gen (2010-2015)
02-04-18 09:10 AM
JoJoJohn
03-09-17 05:08 PM
hisstojay
04-05-16 02:33 AM
relax221
07-12-14 12:07 AM
Quick Reply: rx 330 rear hatch won't open
