Slight Power Steering Sqeek
Old 01-05-15, 11:41 AM
Seadaddy
Seadaddy's Avatar
Default Slight Power Steering Sqeek
My 2004 Rx 330 with 109k miles has a very faint slight sqeek after I start the car. As soon as I start to drive forward , even a couple feet, it goes away. Power Steering fluid us full. Is this anything I should be concerned about at all, can I get rid of sound, and why is it happening?
Old 01-05-15, 11:47 AM
kornpeef
kornpeef's Avatar
check the drive belt. is it cracked? is it stretched? you can diagnose by having a spray bottle with water. duplicate the conditions when u you would normally hear the noise. when you hear it spray the belt and see if the noise goes away. if it does you need a new belt. if you grab the belt and there is more than an inch of travel in both directions the belt is worn and needs replacing.
Braz60
07-15-16 08:13 AM
victorvaj
Performance & Maintenance
01-21-13 10:00 PM
CSGS
Maintenance
01-04-13 07:59 PM
Norbecke
08-30-12 11:58 PM
blaktino47
10-25-10 12:10 PM
Quick Reply: Slight Power Steering Sqeek
