Radiator Cap Assembly broken
Old 01-25-15, 03:31 PM
hayhayday
hayhayday's Avatar
Default Radiator Cap Assembly broken
Does anyone know what this part is called. I cant find this part, the part diagrams seem to have the cap in the middle of the radiator rather then on drivers side.
Old 01-25-15, 04:10 PM
lexus997
lexus997's Avatar
What year and model vehicle?
For a 2008 RX350, this part should be as follows:
164310A380
INLET, RADIATOR WATER
Old 01-25-15, 05:13 PM
hayhayday
hayhayday's Avatar
2007 rx350.
Any suggestion where to buy that part when I google it only a few european sites come up
Old 01-25-15, 05:34 PM
lexus997
lexus997's Avatar
It should be the same part number listed previously for both a 2007 and 2008.
Try; http://lexus.sewellparts.com/oem-cat...X350-2007.html
OR, your local dealer.
Old 01-12-18, 09:08 AM
Sammorax
Sammorax's Avatar
I need this part please, where can I get it?
Old 01-12-18, 09:10 AM
Sammorax
Sammorax's Avatar
Originally Posted by hayhayday
2007 rx350.
were you able to get it and fix please? Mine was broken when trying to remove the battery.
please assist on how to get the part and installation procedure.
Old 01-12-18, 11:30 AM
Mesquite77
Mesquite77's Avatar
These are actually pretty easy to get, AutoZone, Advance, Walmart, Toyota or lexus. They break easy and are called: "Radiator Filler Neck", and the Lexus 2008 uses exact same part as Toyota Sienna Van. I got a "Dorman" it was perfect fit.
Search Youtube, there are a couple of DIY's for this exact thing, mostly about how to deal with the big C type clip.
Walmart:
https://www.walmart.com/ip/902-408-R...&wl13=&veh=sem
Old 01-12-18, 11:55 AM
Sammorax
Sammorax's Avatar
Walmart:
thanks so much... If you have a look on the procedure in YouTube please share.
your response is well appreciated
Old 01-15-18, 12:48 AM
hayhayday
hayhayday's Avatar
I bought amazon , there is a clip which didnt want to come off so i just carefully cut off with dremel and new one popped back on ~10 mins
Amazon Amazon
Old 01-15-18, 11:03 AM
FloorJack
FloorJack's Avatar
Plastic parts suck.
Seems like an EZ fix though.
banyan
07-03-17 11:02 PM
Jetstar
Hybrid Technology
12-17-16 02:09 PM
AtlPeter
04-12-15 04:39 PM
skullkandy
06-15-14 08:46 PM
rody1285
01-26-12 09:15 PM
Quick Reply: Radiator Cap Assembly broken
