Long shift from 1st to 2nd
Old 03-10-15, 07:28 PM
LazarusLng
LazarusLng's Avatar
Default Long shift from 1st to 2nd
Like the title says, I sometimes experience a long shift from 1st to 2nd. When the transmission is cold, it seems to shift fine from 1st to 2nd. It isn't until it is warmed up that I get a looong shift. It winds up,,,,, then it shifts. I have no problems in other gears. Anyone else experience this?
Old 03-10-15, 07:30 PM
Carver
Carver's Avatar
Any idea of the service history of the trans? How many miles?
Old 03-11-15, 03:16 AM
LazarusLng
LazarusLng's Avatar
94000 miles. I drained the pan about 1000 miles ago.
Old 03-11-15, 06:22 AM
Carver
Carver's Avatar
Was it doing it prior to the drain? When you have a problem it's very helpful to 'tell the tale' so there aren't 15 posts just dragging out basic info about the situation.
Considering that it's a very expensive piece of equipment and you have just serviced it I would bite the bullet and have Lexus diagnose it before very much longer.. The fact that it exhibits the behavior so soon after a fluid change is possibly significant.
Old 03-11-15, 07:22 AM
LazarusLng
LazarusLng's Avatar
It was doing this before the change. It does not do this every time.
Old 03-11-15, 08:02 AM
LazarusLng
LazarusLng's Avatar
According to Lexus online service records, it has not had any service done to the Trans prior. Including any updates to the computer. I have preformed the reset, there was no change. Sometimes it shifts fine. There seems to be a window between very slow acceleration, and mid to high acceleration, where the long shift is more likely to occur.
Could the throttle position senson cause this?
Old 03-12-15, 09:55 AM
LazarusLng
LazarusLng's Avatar
Any ideas? what is the procedure that a mechanic would go through to diagnose this issue? I don't want to spend a bunch of money to diagnose a bad transmission. If thats the case, ill drive it until it fails....
Old 03-12-15, 10:21 AM
fastnoypi
fastnoypi's Avatar
maybe you need your transmission software updated http://repairpal.com/transmission-co...-available-154
Old 03-12-15, 02:23 PM
LazarusLng
LazarusLng's Avatar
Thanks, fast. I will look into that. it is possible that that is the problem. I am wondering if anyone has had a similar problem?
Old 03-12-15, 04:52 PM
LazarusLng
LazarusLng's Avatar
Update: I just went out and performed a little test. I manually shifted starting at the ”L” position, and went up through the gears. It shifted just fine, no excessive wind up before the shift. I did this a few times just from L or 1st to 2nd, and it shifted normally. I take this to mean that the issue is not with the Trans itself, but with something telling it when to shift?
Old 03-13-15, 06:01 PM
RX3302004
RX3302004's Avatar
My 04 seems to roll from 1st to 2nd instead of shifting like it does in other gears. Not an issue but strange.
dannyk8232
IS F (2008-2014)
13
05-11-23 12:43 PM
Pantera
RX - 3rd Gen (2010-2015)
04-20-18 06:31 AM
Jahswill
10-02-17 03:00 PM
Bocatrip
04-08-17 03:34 PM
Hostile
SC- 1st Gen (1992-2000)
07-17-11 08:02 PM
Quick Reply: Long shift from 1st to 2nd
