2007 RX 350 - TRAC & VSC, ABS, BRAKE LIGHT come on intermediately
Old 03-21-15, 09:42 AM
thomasfx10
thomasfx10's Avatar
Default 2007 RX 350 - TRAC & VSC, ABS, BRAKE LIGHT come on intermediately
I have a 2007 RX350 and these lights come on intermittently --> TRAC & VSC LIGHTS ON. ALSO ABS, BRAKE LIGHT. When I turn the car off and on again they would disappear. So I cannot take it to Autozone (For code read) because the problem goes away when car is shut off/on.
I believe it is tied to the front brakes which are new but the steering wheel shakes when braking. I had the rotors turned a year ago and it seemed to have fixed the problem but now the shakes are back and so is the light problem.
This makes me think that there is a loose connection (Wire / connector) around the front brakes. If anyone knows where it could be located I would appreciated it.
Thanks!
Old 03-21-15, 10:14 AM
LazarusLng
LazarusLng's Avatar
I have had the same thing in my 2004 rx330. I was told that it is very likely the brake light switch. Inexpensive part, but a PITA to replace. I have not replaced it yet. It hasn't happened in over a month, and the brake lights still function properly.
Old 03-23-15, 10:05 AM
mandyfig
mandyfig's Avatar
It has to be the brake light switch. There has been a DIY on this.
Chiguylay
08-30-16 01:55 PM
thomasfx10
04-09-15 06:40 PM
cjnichls
09-21-12 07:35 PM
Poisson
06-14-11 03:28 AM
samarooai1
02-14-10 02:22 PM
Quick Reply: 2007 RX 350 - TRAC & VSC, ABS, BRAKE LIGHT come on intermediately
