2006 RX330 - Window not working correctly
Hi All. Awhile back I did get my battery replaced and I did reset my windows so they could be used from the driver side panel. As of now, I can roll down all of them from the driver side except for the passenger side rear (window diagonal from driver). The window does roll down from the door itself so the window isn't broken. The light on the driver window switch is lit green, not blinking. However, the light on the window switch on the passenger door is NOT lit and not blinking either. And yes, I did make sure the window lock was not on.
Could the switch, either passenger or driver door, be bad? Should the battery be disconnected and reconnected??
I had the same problem. You need to reset your windows once again as stated in the users manual.
I could not lower one of the rear windows, can't remember which one, from the driver's side switch but I was able to lower it from the rear window's switch. I remember resetting all of the windows and everything is fine.
I need to reset all of them just for the one window? Because I tried reseting just that one window several times and it didn't work. (Rolling down half way, then rolling it up and holding up for a few seconds.)
If I have to reset all of them, is there any particular order I need to reset the windows?
Santa01 (10-22-20)
I tried reseting all the windows but it still didn't work. Maybe I'm doing something wrong. The windows were already set except that one.
Do I have to disconnect the battery to maybe them all be resettable?
I've never actually disconnected the battery. Is it just as easy as unscrewing the connectors and then reconnecting them? Which one do I disconnect first? Do I have to do anything before disconnecting it? Is there anything to do after I connect it, besides reset the window?
I had the same frustration trying to get my RR passenger window to operated from my drivers side control. For no good reason I decided to check the micro fuse under the left side of the dash. After identifying the correct fuse I pulled it and found it to be OK and put it back in. I was very surprised that the RR window now operates from my front switch as well as at the RR door. Good luck.
Santa01 (10-22-20)
ccarruth
06-04-19 03:58 PM
