Clunk noise from the rear during slow speed
I'm dealing with exactly the same issue in my 2007 RX350 FWD. I've replaced everything you've replaced and while I was switching out my winter tires for summer tires yesterday I noticed what I think may be the culprit. If I've identified it correctly, I believe it is the subframe bushing that is worn which is allowing movement between the frame and the subframe in the rear. I'm investigating whether this can be replaced with the subframe still on the car. To remove the subframe and replace the bushings at a shop would cost more than the car is worth at this point.
davintosh (04-29-23)
