Engine running worse after spark plug change
Just had mechanic change spark plugs @141k miles, 2005 rx330. Gas mileage is worse and acceleration is worse. Four days after picking it up, the engine totally stalled as I was idling at a stop light. It cranked back up immediately and it hasn't happened again, but before I call my mechanic, I wanted to see if there was any input from you guys. What could the problem be?
the easy stuff to check for is the connections of the airbox to the throttle body..otherwise, there are a few other possibilities that may be causing your poor performance depending on the method your mechanic used to get to the plugs. Any vac leaks from poor sealing of the intake manifold, missed vac hose connections, improper torque spec of the spark plugs as well.
