Rx330 catalytic converter swap?
Old 11-08-15, 04:55 PM
Gmachine
Gmachine's Avatar
Top left is engine RPM, MAF g/s 45MPH downhill. Bottom left calculated fuel consumption based on MAF & coolant temp
Same as before
Same, but with a slight uphill
Old 11-13-15, 11:48 AM
fastnoypi
fastnoypi's Avatar
what units is the RPM/MAF digital reading in? it would be helpful if it were in volts or g/s. I would also suspect something going on with your MAF. If you haven't tried already, clean the maf sensor wire with CRC maf or electronics spray. A bit of oil or grime can throw it off.
Old 11-13-15, 03:45 PM
Gmachine
Gmachine's Avatar
Replaced both downstream O2's & it's good! I updated the first post to reflect my journey. Thanks for everyone's help. Glad I didn't pay $2000 for new cats!
Old 11-14-15, 07:05 AM
fastnoypi
fastnoypi's Avatar
Glad you found the culprit and problem solved!
Old 01-27-16, 08:22 AM
pluciorx
pluciorx's Avatar
Hi I'm having exactly the same issue with both the same codes (but on RX300 ) , which part numbers did you use for the o2 sensors which fixed the issues ? I'm struggling to find which ones are those and where they are located.
Old 01-28-16, 02:05 PM
pluciorx
pluciorx's Avatar
Hi again do you remember maybe what are the part numbers for the intake manifold's the old and new designs ?
I found 17109-20130 and 1710-920100 for
as well what was the part no for downstream o2 sensors ?
Old 04-10-16, 05:12 PM
Gmachine
Gmachine's Avatar
Sorry, I haven't been on here in a while. I just bought the plug & play O2 sensors, Denso brand, of Amazon. Don't use the spice in ones. They didn't work on mine & have caused me a TON of agrivation!
djensen623
01-23-23 01:04 PM
theazz
12-19-15 08:45 AM
johnblagg
02-08-12 02:57 PM
TunerLexx
Performance & Maintenance
06-28-10 01:32 PM
ivnnln
01-30-10 06:04 PM
Quick Reply: Rx330 catalytic converter swap?
