Vibration (very bad)
Old 10-11-15, 11:08 AM
Maracus
Maracus's Avatar
Default Vibration (very bad)
Hello first time here. I have a 2006 rx330 which vibrates bad between 40-60. I had a my drive shaft balanced and new joints installed but still shakes.I have bridgestone dueler alenza tires with 5k on them, had them all rebalanced. Still shakes. I have 205k on her. Please help.
Thanks!
Old 10-11-15, 06:23 PM
Band
Band's Avatar
Tire(s) out of round?
Old 10-12-15, 04:39 AM
Maracus
Maracus's Avatar
No my tires have been checked extensively and road forced balanced. The problem started on a recent trip to Las Vegas. On the hwy and a few hours into my trip and the vibrations starts.
Old 10-12-15, 05:00 AM
alchemist
alchemist's Avatar
Start from more common and go from there:
Rotors
Tires
Wheels
Control arm bushings
Bad bearing
Old 10-12-15, 05:03 AM
Maracus
Maracus's Avatar
Ok I will. Brake rotors can make your vehicle shake when not applying the pedal? Just asking
Old 10-12-15, 05:09 AM
alchemist
alchemist's Avatar
That is likely not it but i threw it in there. Also check tie rod ends.
I did a thread on control arm bushings. I have a similar vibration 65-75mph. I also did struts, axles and new rotors. I will soon do steering rack which is common failure on these cars but i dont think its the cause of tje vibration.
I still have factory tie rods and bearings. 140k miles on mine.
If u figure it out report back.
Old 10-12-15, 06:04 AM
05RX330TX
05RX330TX's Avatar
If shake when you applying the brake in high speed then definitely your rotors, happened to my 05 changed rotors and the problem gone away, you might as well change your the pads since your already there.
Old 10-12-15, 06:15 AM
Maracus
Maracus's Avatar
No the vibration is not when braking, just driving between 40-60. Shakes so bad my passenger seat moves
Old 10-12-15, 07:15 AM
alchemist
alchemist's Avatar
mine sometimes shakes so bad I have to pull off interstate...
Old 10-12-15, 07:24 AM
05RX330TX
05RX330TX's Avatar
Try the least expensive first Tires, Wheels if the problem still occur then I guess you have to bring to the dealership or local auto shop. Good luck and let us know the findings
Old 10-12-15, 04:11 PM
litzdog911
litzdog911's Avatar
Does the shaking change if you swap the wheels between front/back?
Old 10-13-15, 01:23 PM
iluvny
iluvny's Avatar
Good question. I was going to ask him if he feels it in the steering wheel or the driver's seat.
Old 10-15-15, 01:24 PM
rxonmymind
rxonmymind's Avatar
Been there done that. Lol.
https://www.clublexus.com/forums/rx-...on-solved.html
It was the tires.
First check all bushings and ball joints. Do the tire test. Witht he wheel up in the air a bit grab the 9/3 o'clock position on the wheel and shake side to side. Then 12/6 do the same. Start there.
shajbot
09-21-11 08:09 AM
gappell
ES - 5th Gen (2007-2012)
06-30-09 09:02 PM
SilverGS3
10-22-04 10:58 AM
Lex-Toyo
04-28-01 09:41 AM
Lex-Toyo
04-15-01 11:43 AM
Quick Reply: Vibration (very bad)
