Mysterious clunk/click noise when turning - just replaced strut
Recently replaced the two front struts and noticed the passenger side is exhibiting this peculiar clunking/clicking/popping sound when turning. It mostly happens when turning in motion but once in a while when parked. Clunk/click sound usually only occurs once, or in a short series of 2-3 times, during turning.
Noise is almost silent at the strut mount/bearing, so I suspect it's lower in the assembly. Can feel the clunk/pop vibration with hand placed on the lower spring seat.
Took the tire off and thoroughly inspected things. No tears/leaks in any joint sleeves/bushings. Tie rods and CV joint look fine, as do strut mount, bearing, upper spring seat, insulator, rubber bumper, sleeve, and spring. None of these were replaced during the strut replacement as everything looked great and with only 55k miles.
I've not been able to reproduce the issue with the engine off, nor when the tire is off the ground when jacked/lifted.
During Google searches, it was suggested the culprit is likely either the strut mount/bearing or CV joint. We removed the strut today and everything looks the same as during the install. We can't reproduce the sound with just moving the knuckle around with the strut removed. Strut mount/bearings look in excellent condition:
