Strut coil spring bad?
Old 12-30-15, 04:31 PM
dganapol
dganapol's Avatar
Default Strut coil spring bad?
All,
I have been having a hard time getting the spring to compress correctly. They have to be in the center for the mount to go on. I have tried the floor model as you can see from the picture and also the manual spring compressor. I was able to do one side, but I had to fake out the compressor. There is no way they can be made this way. They have 163k on them. Let me know what you think.
Thx,
David
Attached Thumbnails Strut coil spring bad?-pic-1.jpg   Strut coil spring bad?-pic-2.jpg   Strut coil spring bad?-pic-3.jpg
Old 12-31-15, 03:20 PM
dganapol
dganapol's Avatar
Update #1
I found the spec on the height and it is 392.6mm which is 15 and 29/64in , I measured the spring and they are at 15in, new ones on their way.
David
Old 01-03-16, 04:38 PM
Lazyj321
Lazyj321's Avatar
Not necessarily Lexus but I have found spring generally compress from new once they have been used for a while, so being less than a 1/2" doesn't seem like a big deal, Is it normal for the spring to be curved like that?,that's why your compressor won't work? What manufacturer shocks did you end up with?
Old 01-04-16, 03:32 AM
dganapol
dganapol's Avatar
The compression is normal it is the bend in the spring. This is the reason I cannot compress. I even used the manual type and could not compress enough. I looked at the pictures of the DIY post and could not even make the spring look like that one in the picture. Waiting for new ones from Lexus.
Thx,
David
peterls
16
10-27-18 06:48 PM
jvah1980
08-19-17 07:57 PM
Alphaman19
Suspension and Brakes
05-13-15 04:47 PM
MrJohnE
Southeast
03-22-06 04:41 PM
Quick Reply: Strut coil spring bad?
