Annoying rattle from the tailgate? try this
I found out that the tailgate latch moves against the metal hook on the body and it rattles during travel.
I wrapped the metal hook with insulating tape and the sound is gone now. nearly lost my mind trying to find the rattle. ah the sound of silence!
(this is only a temporary solution; i guess i will have to re align the latch or the metal hook permanently)
i remember seeing a hard plastic casing on the hook on a car i dont remember the brand of. Wonder whether I can buy a hook with such a casing so then i wouldnt have to keep changing the insulating tape of if i used foam insulation, the foam tape.
I've never changed the foam tape over 8 years of ownership.
Also, I remember now that some foam tape was put under the little flap as well.
You can see from the photo that tension was put on the tape, which held the metal hook tight to the door.
crz95 (01-08-20)
Are you sure it's the hatch? I've been tackling rattles since November (when I bought it). I did the sway bar links and bushings, insulated the hook for the hatch with electrical tape, tightened the spare tire and found where my missing jack and lug nut bar were (I thought they were missing, but I found them under the bins)... still have rattles. I'm leaning towards the right rear strut or axle carrier bushings. They are the only things left I didn't replace yet... LOL
MY13GS350
04-26-12 01:24 PM
