RX330 valve stem seals replacement DIY
That consumption is within normal tolerance for most vehicles, personally I'd live with it (and did years ago with an Audi that burned ~1qt between oil changes starting around 80k miles).
I always thought you'd have to take the heads to a machine shop to replace the valve seals, however this website about Lexus V8s just schooled me:
http://lextreme.com/valve_seals.html
What viscosity oil where you using when you lost that quart? Wife's 08 scion with 111k miles loses 1 quart using 5-30 but loses 1/2 quart with 10-30 after 5k miles. Suggest you try a thicker oil.
id start with the small less invasive stuff first like checking the pcv system and including cleaning out the baffles in the rear valve cover before considering valve stem seal replacement. Both can be the cause of oil consumption.
While the rear valve cover on the rx330 is a considerably better design than that on the rx300, it can still be prone to clogging with sludge with short trips and infrequent oil changes.
thank you all for the responses. My rx330 has 190,000 miles on it. I use 5W30 every 5K miles. Will check the rear valve cover as well. As I am not really sure what the rear valve cover does, can someone point me to the right direction?
autoXlex
06-13-12 12:37 PM
