Bad gas cap?
Is it possible for a bad gas cap to throw a code of 2195? How can I tell if the cap is bad? In some cars you could hear the seal being broken when opening the cap but I have never heard the seal on my 2007. Visually the cap seems fine.
Thanks
Thanks
I don't know what a code 2195 is but I did have an issue that resulting in the check engine light coming on. Back and forth with the stealership who would reset the code and tell me there's nothing wrong.....would last till the next tank of gas and happen again. These idiots even told me to shut off the engine when refueling, this is after I had the car for 3 years and not had the problem. Long story short I found there was a recall on the fuel pipe, replaced it and no more issues.
What makes you think it is the gas cap? Code 2195 possible causes are:
- Faulty Oxygen Air/Fuel Sensor Bank 1 Sensor 1
- Oxygen Air/Fuel Sensor Bank 1 Sensor 1 harness is open or shorted
- Oxygen Air/Fuel Sensor Bank 1 Sensor 1 circuit poor electrical connection
- Faulty EFI Relay
- Faulty Injector
- Faulty Engine Control Module (ECM)
Read more: http://www.autocodes.com/p2195_lexus.html#ixzz42A0PoPdd
This TSB is also interesting:
Make : LEXUS Model : RX350 Year : 2007
Manufacturer : TOYOTA MOTOR CORPORATION
Service Bulletin Number : L-SB-0109-09 Date of Bulletin : SEP 02, 2009
NHTSA Item Number : 10032515
Component : ENGINE AND ENGINE COOLING:ENGINE
Summary :
LEXUS: ENGINE CONTROL. SOME VEHICLES MAY EXHIBIT A MIL ON DIAGNOSTIC TROUBLE CODE (DTC) P0138 AND/OR P0158 (OXYGEN SENSOR CIRCUIT HIGH VOLTAGE BANK 1 OR 2). IN SOME INSTANCES A P2195 OR 02197 (A/F SENSOR SIGNAL STUCK LEAN) DTC MAY ALSO BE PRESENT. CAUSED BY INCORRECT AIR FUEL RATIO SENSOR RESPONSE. *PE UPDATED 6 /28/10. *PE
- Faulty EFI Relay
- Faulty Injector
Summary :
crwys
27
05-09-14 07:00 AM
