Strange electrical problem rx330 2004
Today the blaring alarm came on for no reason while parked in the driveway.
When I got to the car the remote key didn't work, the driving headlights were on and the radiator fan was on, and stayed on. Also could not unlock the rear gate.
I checked for codes with the OBDII tool, no codes.
I could only stop the fan and the lights by disconnecting the battery.
I reconnected the battery an hour later, the fan came on and stayed on. I removed the fan fuse but the lights are still on.
What is happening?
Pretty heavy rain last night, otherwise mild day in Southern Ontario.
Anyone has experience with this trouble?
What is happening?
The next day the problem appeared to go away. Drier weather maybe?
But now the battery trouble sign comes on and off and while driving the engine cut out for a second or two, and came back on. It happened three times in a matter of 10 minutes. I checked for codes again with OBDII, no codes.
Where can I find the proper wiring diagram for RX330 2204?
JMan23
05-09-19 02:08 PM
