Key Igntion/Locked Steering Wheel Issues
Hi,
I have a 2008 RX 350 and I am experiencing issues with turning the key ignition and having the steering wheel locked. It gets locked and after several attempts at jimmying the key it eventually starts. My concern is that if I keep this practice up I will damage my key. I have addressed this issue to the dealership and I was naive and trusted them with fixing the problem with my last maintenance visit. Thinking the the problem was solved I started to experience the same problem again. I was first told that it is possible the my key chains are too heavy which could of caused the problem but I lightened the load and still have this problem. I've read about this problem with other people but there doesn't seem to be a solution.
One thing I have noticed is that I tend to experience this problem during the cold weather. During warmer weathers I don't have issues with the key ignition being locked but now that it's cold I am having the problem again (not sure if this has to do with anything). Do I need to change a part out to fix this? I've also read that there can be dirt in the ignition which needs to be cleaned out. Will this work and if so how do I do clean it? Thank you in advance for your time and any suggestions you guys may have to offer.
Mine had this intermittent issue and required a new ignition lock cylinder.
https://www.clublexus.com/forums/rx-...ml#post7978897
That fixed it in mid 2013. Hasn't happened since.
1koolfella
08-20-14 12:11 AM
