water leak from tail light
Old 04-20-16, 11:57 AM
DennisMik
DennisMik's Avatar
Default water leak from tail light
We have been having a bit of rain her and I decided to check the carpets in my 2007 RX350 to see if they might be wet from a water leak. The carpets are dry but I did have a swimming pool in the pocket in right rear corner of the cargo area. I removed all the stuff so I could bail out the water and inspect.
I think it is leaking in from the tail light assembly as I saw wetness on the vertical metal below the tail light.
So my question is: How do I remove the tail light? I removed the access panel that lets you see the backside of the tail light and I can see 3 bolts. Are these 3 all there are? Since the tail light wraps around the side, there is most likely something holding that edge down. Is it a pop clip (or something) or will I have to remove the inside trim panel to get to a bolt?
I would appreciate any help you guys can give me.
Majek
03-08-15 12:37 AM
dbui
RX - 1st Gen (1999-2003)
10-17-11 07:19 PM
wjkjr
SC- 1st Gen (1992-2000)
04-04-07 07:50 PM
thebanez
09-03-05 02:20 PM
Quick Reply: water leak from tail light
