Disabled the DRL and added LED DRLs
Old 05-08-16, 11:23 AM
mandyfig
mandyfig's Avatar
Default Disabled the DRL and added LED DRLs
Finally did my LED DRL install.
Disabled the DRL that uses the high beam and hooked up the LED's to light when the engine is running. Serves as my DRL.
Old 05-10-16, 05:57 AM
mandyfig
mandyfig's Avatar
Wow, the flaming has not started?
Old 05-10-16, 07:19 AM
draco
draco's Avatar
How did you wire it up? The Australian delivered RX doesn't have the drl fuse, and I have been wanting to add some drl' to my car. Be good to know how and where you wired it up.
Personally not to my taste, but your car
Old 05-11-16, 09:21 AM
mandyfig
mandyfig's Avatar
Simple, went to the fuse box and selected a fuse that is IGNITION "ON" and wired my + on it. I simply pinched the wire with the fuse, all done! I wired the negative to the battery minus. Very thin wires needed. The LEDs just need a tiny fraction of current to operate.
And they are very bright. More so at night.
Old 05-11-16, 09:25 AM
mandyfig
mandyfig's Avatar
I tied them in parallel and ran the pair of wires through the hood underside panel with tie wraps. I will take pics and post.
PICS:
Note: You will need to cut into the lip of the fuse box for it not to pinch the wire.
Old 05-11-16, 10:14 AM
mic575
mic575's Avatar
I think it looks good. Dit you order them on ebay?. Matches your SC nicely.
Old 05-11-16, 01:19 PM
mandyfig
mandyfig's Avatar
xmazon actually, they have come down on pricing. Just not sure they are made by 1 company, they are supposed to last a zillion hours, $10 for a pair.
Old 07-17-18, 08:39 AM
mandyfig
mandyfig's Avatar
They are now 3 sets for $9, wow! Must be a lot of makers nowadays. A set died (one installed on my CRV), hence bought some.
Old 07-17-18, 11:38 AM
joedaddy1
joedaddy1's Avatar
hmmm.. looks like it belongs in a 1992 corolla in the light gold color.
it would be nice to have a smaller DRL in the fog light housing.. like last-gen Prius.
(Pix stolen from the internet)
Old 07-17-18, 12:30 PM
edwardh11
edwardh11's Avatar
on my 04 highlander I disabled the DRL[ they were melting the lamp lens
Old 07-17-18, 01:01 PM
mandyfig
mandyfig's Avatar
These LEDs are very bright during the daytime and add lighting at night.
Lexusblack
RX - 1st Gen (1999-2003)
06-13-14 05:49 PM
tokio417
05-02-13 02:41 AM
sidwin
SC- 1st Gen (1992-2000)
11-21-12 12:57 PM
bsan703i
Lighting
11-20-12 08:33 AM
foam
07-29-12 08:26 PM
Quick Reply: Disabled the DRL and added LED DRLs
