Passengers windows won't roll down from driver side master controls
This was posted by Canhzx (btw - THANKS!!!!) and it worked for me on a 2007 GX470 and is worth a repeat:
"If the Rx ever lose power you will need to reprogram the switches. 1st you need to turn the ignition to on. 2nd go to each door and roll down the window AND continue to hold it down for 3sec. then roll it up AND hold it for 3sec. Repeat the step on all door EXCEPT driver door."
Try resetting the windows
I have the same problem with a 2007 rx350. I tried everything you did but check the connections in passenger door. Is yours still working or was this a temporary fix?
I had also tried to have the passenger door open and tried to open windows from drivers door. Still does not work. Each individual door button works perfect.
ne0tekk (04-11-18)
