Can you change oil filter without draining all the oil?
So I went to change the oil today and was not able to get the filter off (the mechanic had put it on too tight). I normally do it myself but it was winter so i had the mechanic do it.
It was on so tight that I had to use a 24" breaker bar and ended up snapping my metal oil filter wrench in half.
This was the one: https://www.amazon.ca/toyota-Aluminu...R6SQKM9W6EYFND
So I ended up just changing the oil and ordered another oil filter wrench. Will I have to drain the oil again, or can i just change the filter? How much oil will come out?
Not the end of the world but I would suggest changing the oil again once you get the filter off. Be sure to coat the gasket with a little bit of oil, bring it to finger tight/sinch, and then turn it another 1/4 turn or so. Nothing too tight....check instruction on filter before installing. If you use a wrench to tighten, it will be very minimal.
A couple ounces come out when you just change the filter. I always remove the filter first on my oil changes, just the way I do it. I would not bother changing the oil, it is almost new.
Over the years, I've had to wrestle off different oil filters on cars and motorcycles that were put on by the gorilla a the factory, or an over zealous DIYer.
here's my 2nd to last attempt tool I use to get the filter off:
https://www.amazon.com/gp/product/B0...=ATH2XNUERSHVZ
my last hope, that always works is a uber long flathead screwdriver. like 18". I only have had to use it twice, the oil filter pliers are magic, most of the time.
good luck.
good luck.
I have owned one of these for the last 50 years. In all that time they have never fail to easily remove an oil filter on any car.
https://www.amazon.com/Channellock-4...s%2C178&sr=8-1
lilbluu
06-01-10 03:44 AM
ToyotaLexus
Maintenance
02-17-09 01:28 PM
