2004 Rx330 ECU pinouts
I m getting po330 on my 2004 RX330 and trying to figure out whats going on because truck is running very smooth with no issues but keep on getting PO330.
Just looking fot ECU pinouts so I can diagnose the error.
Thanks. Here is the picure of PINS:
![](http://ww2.justanswer.com/uploads/TS/tsmodie/2012-09-20_180422_1.jpg)
Telefunken (08-07-19)
To get the read out on the knock sensors, I am looking for ECU Pinouts. What two pins are for knock sensors on ECU?
Don't go to the ECU, find the knock sensor plug and ohm it out. Also take a hammer to the block while you are on the pins and see if it generates some voltage, don't bang the crap out of it just small pinging hammering. Check both of them.
David
David
With engine running (using multimeter)check the reading bewteen PIN 1 and 28 and compare with 2 and 20.
My test showed that knock sensor 2(pin 2 and 20) was showing totally different reading consistantly then Knock sensor 1(pin 1 and 28), even when I knocked on the engine with a hammer (Gently).
Now after confirming that the problem is a BAD knock sensor since reading is not changing even when I knocked on the engine, instead of disassembling half of my engine to replace it, I just cut the wire of pin 2 (RED) and connected it to pin 1 (Black) on ECU side and cut pin 20(green) and connected it to Pin 28 (White) on ECU side. IT's plug E9 in the picture.
No more check engine light with error code PO330.
Please do it at your own risk, I am not responsible if you damage anything while attempting this.
![](https://www.clublexus.com/forums/data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAX8AAADVCAIAAAAw1mcMAAAgAElEQVR4nOx9d1xU17Y/ptyb9+69uXn33Xzeezc3idHEFpViyzUaWzQajd2osSBNQEFQUAQEBARBOlJVrPRmoQhI7x2kM8DM0DsjAzPDtHN+f6wf+3M8wwwlMKL3fD9+/Awz++y+v2fttddaWwGnQOFdgcJ4eNMVpPAaqPGg8O6AYp+3C9R4UJhZ9P/za/gnh7Io9nm7QI0HhZkFxT4UpIEaDwozC8Q+8uEgin3eIlDjQWEGQaIein0oEEGNB4UZBMU+FGSAGg8KMwiKfSjIADUeFGYWFPtQkAZqPCjMLCj2oSAN1HhQmFnImX1wmQQkh9IpTBzUeFCYWVDsQ0EaqPGgMLOg2IeCNFDjQWFmQbEPBWmgxoPCzIJiHwrSQI0HhZkFxT4UpIEaDwozC4p9KEgDNR4UZhYU+1CQBmo8KMwsKPahIA3UeFCYWVDsQ0EaqPGgMLOg2IeCNFDjIVeIxWL0WSQSkX7FMAzDMPS9WCwWCoUjIyNDQ0MvX74sKiqKiIgICQlxcXG5fv26o6Ojs7OzjY3N9evXnZ2dHRwcvL293d3dExIS4uPjW1paOjo6+Hy+QCCAnFH+APQlMcFMgGIfCtJAjYdcAYscOEgoFOKExU9a/yMjI3w+H8OwoaEhPp9fWFhYXFwcHBwcEhJiZ2fn5ubm6upqb2/v6up67do1a2trR0dHT09PNze35OTk5ORkJpPZ0dHB4/H4fL5YLCay3pgQiURAdtPeZIp9KEgDNR5yBbAAiWjgS1j8XV1dfX19AQEBYWFhv/766759+7755ptFixYtXbp02bJlR48ePXDgwPnz5/X19U1NTW1tbc3Nza9evWpnZ3flypXTp0/r6upu3Lhx+/bt8+bN++abb5SUlBQVFc+fP29kZJSenp6amgqSlFgsBgmLVJ9xSWoKoNiHgjRQ4/EGAIIG0A2GYbDmQQgaHBzs7e19+PBhQEDA7t27d+7cOXfu3EWLFi1fvnz58uVHjx7ds2ePoaGhsbExUM+1a9dMTEysrKwsLS01NTV1dXU3bdq0ffv2BQsWzJ8/f8WKFcuXLzc0NLxw4UJGRkZWVtbIyAiUjhO2fmKxWCAQCIVCin0oyBPUeMgPkiIGrH82m81msx0cHNzc3BYvXrx8+fJ9+/bt3bs3MDAwLCysoaGBwWBwOBwgCPQUSaEDGfL5fKFQyOFwGhsbGQxGXl5eQUGBtbW1paWlkpLSokWLtmzZsmnTpsTExOTkZFKtUA7T22p58g6AYp+3BdR4yA8ikYhEFlwuF8MwLpcrEAhAc7xq1aolS5bs2bNn165d9+7dCwgIYDKZtbW1oH6W1A0LBAKSFnlwcJDD4TQ3Nzc3NxcVFRUUFFy9etXGxmbx4sVLly7dsGHDtm3bkpOT09LSoAKQDyLEmRB/5AyKfd4WUOPxBgB7H4FA0NDQ0NDQsG7duvXr12/ZsmX79u15eXl5eXktLS0MBuPTTz/93//9388+++zrr7+eO3fu/Pnz586d+/nnn8+dO/fLL79UVFRcunQpk8lkMpkcDofH4xkYGOjp6S1ZsuTLL7/87rvvVFRULCwsLC0tR0ZG2Gw2h8Pp6+u7ffu2r6/vl19++cUXX1haWrq5uQ0MDAiFQpFIBMLUOwCKfd4WUOMhV5DOtmpraysrKzdu3Lhhw4adO3du2rSppKSkoKCgvr6eTqd/+umnn3766VdfffXVV199/vnnX3311Zdffjlv3rwvvvhi/vz5ioqK3377LYPBYDAYLBZrZGTk7NmzRkZGX3/99YIFC7777rvVq1ebm5tbWVnxeDwul9vf39/f3+/v7+/n5wdEZmdnZ2NjA7+iKlGyDwW5gRoPuQIdb9FotPr6+mXLli1fvvz69es2NjZCoZDH40EyBoPR2NiooKDwwQcfpKSkZGVlAcuATMRgMJqbm9vb27u6usRiMYZhERER4eHhCxcuVFJSYjAYTCaTz+fzeLzffvvt5MmTd+7cuXv3LnF31tTU1NjYuH79+nXr1p07d+7cuXNwwP8Ge2YaQbHP2wJqPOQKxD51dXV1dXXffvutkpKSra2th4fH8PAwnH8JBAKgGFgw2dnZqampDAaDTqcD7wAHdXR0NDc3A5sEBQWFhYUpKiouW7YM0vD5fJFIdOLEiePHjwcFBXl5eeE4DgZEGIa1t7c3NTWtX79+48aNOjo6xsbGw8PDLBYLH1Vmv9Wg2OdtATUe8gaHw+FwONu2bfvxxx/hpBzHcTabDb/CqVZra2tDQ8P777+voKBAp9Pr6+vhV+AaOPMiGi7++uuvv/76q729/bVr1yATSPP48ePExMRvv/129erVcBwGjwuFQqFQ2NbWRqfTv/vuO2Vl5YcPHwYFBb0D2y6cYp+3B9R4yBsCgYDD4fz888+bNm2ytLQ0NTXFR0kHgclk0mg0BQWFOXPmVFVVIfbBCaQjFouHh4fhy0OHDh06dMjBwcHR0ZGYMikpKSYmRklJadmyZfioXIPKotPpbW1tq1evVlFRefToUUBAAMU+FOQJajzkB9hYxcTEvHjxQllZ+YcffoDTcZzAKWDU09jY2Nra+sEHHygoKLi6ujo6Ovr7+9+6dSsgICAgIODevXt3796NiYmJi4sDZY2+vv758+f19PR0dHREIhE6wHrw4MGjR48WLlz4xRdfgMiDagI6JrFYHB8fn5qaumDBguXLl/N4PCSFvb2g2OdtATUe8kZcXNzz589VVFSUlZXhLByXkEpoNFpDQ4OCgsIHH3xgbm7u5OQUEBBw//79+/fv375928/P79atW9HR0U+fPsVxHMOwixcvGhkZ6ejoGBgYEK2KHj58GBgY+NVXX82dOxcplVBNQNJJSEh49uzZt99+u2DBAjabLen7+taBYp+3BdR4yA9wPqWnp2doaOjs7Ozm5ob8rUhoampqbm5+//3333//fdDpqKmpaWhoqKura2lp6erqampq2tnZmZubQ/qsrKyCgoJ//OMf//jHP4yNjc3NzW/evOnu7r558+Y1a9YsW7Zs6dKlOMHKEZwqMAwDBRCO4wsXLlRWVi4sLCwqKpJXf8wUKPZ5W0CNh7yhr6+vp6fn6Ohoa2tL/B6kEpBHGAxGU1MTLJiDBw8eOHBAS0tLW1tbTU1NW1v71KlT2traNjY2oGPGcTwvL6+4uPjzzz//v//7v8uXL1+8eNHT09Pb23vt2rXr1q379ttvly1bJhaLR0ZGID3RuRS00QsXLly0aFFZWVl5ebk8e2MmQLHP2wJqPOQHWO179uzZs2dPYGBgSEgIyB2gQkaCCYZhzc3NdDodzrwaGhrq6upkZIiPyjJFRUUVFRW6uroGBgZ2dnZXr159/PhxRETEN998s3DhQgi1gZ5FZ//w54YNG7Zs2ZKampqYmDhjHSAnUOzztoAaD/kBNlk7duzYs2fPo0ePHj16NGYysViMrA0VFBTa29tra2vhe7RNgw/oT/CVLykpKS4u1tfX19fXBx+LqKioqKiob775ZvHixUQvdngQcZ9QKAQLgGfPnr148WLGO2KGQbHP2wJqPOQKsVh88eJFExMTCwsLCwsL/PXoYkhb3Nzc3NTU9N5773300UclJSVNTU3EaBiQDLgDTHuys7OTk5Pv379/7949YnFWVlZmZmaGhob6+voof2JkHx6PJxQKBQLBF198sXTp0srKyqqqqhntAVLAjZn4R7HP2wJqPOQHII7z58+bmpra2NjY2dnhBNNB4s6LyWSC3mfOnDmNjY00Gg39hI8SB0TqgRySk5NTUlIePHhw69YtSMnn80dGRkACMjAwMDIyItYEHbfjOD40NDQ8PLxw4cKvv/4aLLBnqPly4B3ZTDRD7aIwZVBDIm+8ePEiPj4ezqH6+vpevXpFSiASieh0ekNDA9j7HD9+/NSpUzo6Ovr6+kZGRnp6erC3MjIyunjxYkNDA5PJzM/PLyoqmjt37rx58wIDAwMDAwMCAu7cubNkyRLwRK2srMRHFcykU7bw8HDw0li5cuXg4CDyNZt2vBH2kX9sMwoTB8U+8gPIGrGxsbm5uUpKSitXrhwaGurp6ZEMtNrS0tLS0jJnzhwFBQUNDY2TJ09euHAB3EH19fUNDQ319PTOnDmjq6sLPFVSUpKXlzdv3ryFCxeGhISEhIQEBAR4eXktWbJkwYIFROkJQAzrExoaGhQUtHr1aiUlJVzC6noa8caph2Kf2QaKfeQKkDtYLNbu3bt3796toaFx/vx58Aglbr56e3tZLJaXl5eHh4ebmxt88PT09PPz8/T09PDw8PPz8/b29vPza2tr6+rqAjZJTU1NSkoyMzMzNjY2MjIyNTWtra1lMBiQp0AgIJ55YRhGo9GYTOY333yzbNmyhw8fBgcHI0vFmcCYRECxz78zKPaRK8RiMfhG7Ny5c+fOnUZGRmfOnEG8gAhoYGBgeHgYbHY8PDy8vLyAgLy9veFLNzc3Dw8PHx+flpaW9vZ2HMeFQmF6enpaWpqJiQkotk1MTGpra+vq6oiEQtRYQ5yNxYsXL1iwIDQ0NDIyckYd3KdMBFPmGkrlPMtBDYlcgaSPtrY2FoulqKi4Zs0afX19HR2doaEhFotFpCHifVvoS6S1IWqpSY+gNKSQPegRsI1evHjx4sWLbW1traysRCLRzGl8AHKTQagDr7cF1JDID3DmBRTQ29tLp9M3bNigoqJiaGhoYmLS3t7e2dlJegSEFBTRmRQWGkD8kmRDiBKgnR0IX6Wlpfn5+UuXLl24cCGwD5HCZqj5FPtQIIEaEnkDcQGO47W1tW1tbfv37//111/XrVu3du3ayMjI0NBQLpeLIoEhm0B8dOMmuZNCn9GfIpEIOAuVRafTW1tbLSwsrl69Cqdjfn5+d+7cEQgEKFKH3HZeM1cKTrHP2wNqSOQHYlQwHMeFQiHEJwRPrpUrVyopKUVGRoIHBtHtC5eQd2TkL+0bOp3OZDLB1Gju3LlLlizx9PT08fEBg0N8dJs2cz7uFPtQIIEaEvkBNj6kyIQgzgiFwsDAwODg4BUrVqxcuXLNmjXfffedjY2NtbU1jUZ7+fIlj8eDiyuIThIQygd/3XyZw+Hw+fyhoaGBgYHY2NjHjx/r6uqqq6vPnz//s88+U1VVPXLkSEVFRUlJCdSK+OyMhteg2IcCCdSQvBnweDy0UeLxeCwWKzQ09P79+yoqKoqKimvXrl2zZo2NjY2Tk1NJSUllZSWfzx8eHhYKhSChkLZIxNtQh4eHBQLB4ODgwMBAYmLi8+fPz5w5o6en99lnn82bN+/w4cMnT56sqqqqqamB9CjqGHjAz1x4Q4p9KJBADYlcIRAISMRBiivG4/EEAkF8fHxcXNzp06fV1NSWLl26dOnSBQsWLFq0aOPGjT/88IOqqupvv/2mpaV1+vTps2fPGhoaqqurq6mp7dmzZ+/evWvWrFmxYgV4lqqoqKxbt87e3t7e3r6+vr66uhpKIV5MCEWjWr2r7DOjJVKYGqhRkTfQOTrJqhg2ZXDyHRcXFxcXp6WlpaGhsWjRoiVLlsybN2/x4sVwC8Xx48cPHz6spaUFwQyNjY01NDROnTq1b9++3bt3r1y5csWKFfPnz//888+3bNmybt06W1tbJyen8vJyJpOJPC2ITq3EU/x39cxrRkukMDVQozJ7AWIIm83mcrk0Gq2mpiYlJSUxMTE4ODgiIsLT09PT09PFxcXe3h6828PCwqKjo/Pz8wsKCtrb29va2tA9FrMBFPtQIIEaldmO4eHhoaGh+vr6yspKYB/QT9+8edPDw8PFxcXJyenevXv3798PCQmJjIzMysoqLCxsbW3t7OyEuD9vugX/HxT7UCCBGpXZC/DAAOFFGokQ900kEA+zZgMo9qFAAjUqbw2QLwU6aEeAb8SjIDphULIPxT6zFtSozGoQ/SckTZyJREP6aRaCYh8KJFCjMqshzb2LxD7ofzg4QxIQJftQ7DObQY3K2wSiKESC5Jezh3cAFPtQIIEaldkLSbd1IqGgbyStdeTgNjEFUOxDgQRqVCjICRT7UCCBGhUKcgLFPhRIoEaFgpxAsQ8FEqhRoSAnUOxDgQRqVCjICRT7UCCBGhUKcgLFPhRIoEaFgpxAsQ8FEqhRoSAnUOxDgYRxRiWOAoVpApF9ZrSgMdlH9iPyWWwUSKDYh4KcQLEPBRLGYZ9GChSmCUT2mdGCxmQf2Y/IZ7FRIGEc9mmiQGGaQGSfGS1oTPaR/Yh8FhsFEsZhH4wChWkCkX1mtKAx2Uf2I/JZbBRIoM4CKMgJ1JkXBRKoUaEgJ1DsQ4EEalQoyAkU+1AggRqVqQNu2hocHBwaGhoaGmKxWMPDw4ODg4ODg1wul81mDw8PczgcSMB+d/Hq1Ssul8tisTgcDtwfPzw8DL3BZrPx0YtSKfahQAI1KlMHn88fGBjgcrm9vb0cDofFYvF4vMHBQRaLBYuQxWLBn2w2GxHTu4ehoaFXr16x2Wz4k8PhcDickZGRV69ecTgcPp8PsRYp9qFAAjUqU8fy5csXL168Zs2alStXKikprVy5UkVFBf6HL1evXg23qgNWvqP4/PPP//nPf65evXrVqlXwzRdffPH5559/8sknf/nLX1B3UexDgQRqVKaOZcuWrVixQllZeenSpf/6178UFRWVlJSAgFavXg1/QgIVFRX4/53EZ5999tlnn6moqEBjFRUVFy9evHDhwj/96U9//etf0VXOFPtQIIEalalDWVl50aJFfD5fIBAQr0svKirKzMyMiooKDAwMCgoKDAwMCQkJCQkJfkdx5cqVy5cv44Qbfh4+fBgeHv6Xv/zlk08+gT4RCARE9plRAqLY520BNSpTh7Ky8ooVK4aGhgYHB3EcF4lEGIaJRKKysrKcnJzHjx8HBQUFBQU9evQoMDAQ/n8ncfnyZXNzcyL/hoeHh4WF/dd//deHH36IvqTYhwIJ1KhMHUuWLFFWVuZyuWjhwSU2HA5neHi4u7u7q6urv7+/v79/YGCgv7+/7x2Fq6uro6Mj9ACGYWKxOCoqKjw8/M9//vPf//53oVAoEoko2YeCJKhRmTpUVFSWLFkiEAhA9sFH79uCg/a+vr7e3t7+/v6enp43zQ8zC3d39+vXrxN7JjIyMiQk5JNPPvnP//xP9CXFPhRIGN/PCz40NDQ0NDRkZ2dnZGRkZWVlZmZmZGTk5ORkZ2dnZWXl5eVlZmaWlZXV19eDcce/AxQVFRUVFblcLpfLJX7f2NjY3NyclZWVnZ2dk5OTmZkJn7PeUVhbW1tbW+Ojgg+GYaGhoZGRkX/5y1/++te/oin0ZtknNzc3KysrMzMzLy8vIyOju7u7vb0dk7iimoI8MSH2EQgEDAajtrY2KysrNzcXkQ6QUUZGBvxJo9Gys7NxHBcKhWgz8g4PrTT2qaura2xshJ6BGZ+VlZWTk/MmGWImYW1tbW9vPzIygnogNDQ0ODh4VrFPdnZ2ZmZmdnZ2SkpKVlZWb29vT08PjuNEdRUFOWOiEqmOjs7Zs2fHHFcFBYU5c+a8//7769at27x5M7pQfHbe5zuNkMY+bW1tHR0d5eXlZWVl5eXlJSUlpaWlZWVlpe8oGAxGZWUljuMYhgkEAgzDwsLCZpvsg/DHP/5RQUHhp59+2rx5M6T/95HWZxvGZx+xWCwUCk+fPq2hoTFnzhwi46D/AT/88MOaNWvwUQn8nX+rSGMfOp3OYDDKy8tLS0sR+8D/7ySYTCadTocjP+iBsLCw0NDQWcg+f/jDHxQUFN57771Nmzbt2LGD4p03i4nKPpqamjo6OgkJCQkJCVwul8Ph8Hi8oaEhcGhqaWlpbm7eunXr+vXr8del2X9D2QcAFCz/WskfGIahEYcmh4eHR0REzCr2AaczNptta2trZ2e3atWqFStWQHo+nz9zlaEgA+OzD4fDwXFcU1NTS0srMTExPj5+eHgY8Q6Px2Oz2Q0NDTQabc2aNRs2bEAmZ+jDuwpp7IN4h9j8d7srSAgLCwsLC5tV7ANmEMPDw3Z2dleuXFFSUlq1atWYrw0KcsM47INUiWpqalpaWpmZmenp6SgcHHq3d3V1dXd3b9q0acuWLf8+y0yG7EOUekh99U5CRACGYZGRkePqfWaOgCSpB/2EYZitra27u/uyZctWrlyJv+vjMssxIb2PWCzW0dHR0tJKS0vLyMhA8wnkbbFY3N7e3t3dvW7dunXr1sFP/w4BK2WwDygUJCWgdxWkNRwRETGu3kfO7AM1FAgEjo6OdnZ2ioqKsPP6dxidWYtx2AdpbU6dOqWjo5OSkpKZmQnfoAmHYVhPT09HR8f69et//PFHydf+7ATR1mNq9Vy6dKmKigqbzR4ZGYEcpl3RjjJEQugUqkoUvmZCGyUWi9E8gbJCQkKQrbNAIJCMsDFZ9kGthoJkN0GSfYijbGdnZ29vDw6xU2kthenDOOyDpqyOjo62tnZmZmZKSgrpJ5FI1NXV1d7evnbt2u+//x5+nc06V9gdIMENnyr7gOwzMjLC4/FgVaBZPi3g8Xg4jguFQtSTIFJNNh98VIDFXz8EmK56ol5FR0jh4eFRUVF/+9vfPvjgA9TJU2YfKAX6YSIaYkn2gQrA//b29o6OjsA+wJuzdqK+85jQmRecuJ88eRJM5ki/YhjW29vb2dm5efNmOPMiPTs9NZ1JYFNiHyUlpSVLlvB4PKAJfJSLp7Vq/58vwI4Gn2p/Sj41tSZPJHMMw4KDg8PDwz/++GOQfeD7adx5yT7QkKH3wXHc3t7ezs4OAp5MuQIUpgUT9bTQ0dHR1NR88eJFcnIyJiHJ9/T0dHZ2/utf/9qxYwcsRYxwCjvbAH6PMIN/z3tPWVlZSUmJw+FwuVzS7mNawOVyiWsMGdRMNh98lMLABp24ZZ4W4KNaZ5RzREQEsM+f/vQnfJKyD8oTAfiLOJ0k0xAx5s4LiT9OTk62trZr1qxRVlbGMIxol09BzhiHfdDAaGlpaWlpeXh4ODo6xsbGxsbGxsTExMXFwedHjx49ePDg73//+0cffbRr165t27Zt3759586d27Zt27x580+zDDtGAX9u27ZtavnA6oqKioqKioIOiY+Pf/bsWew0ISEhAbJ98uTJs2fPYmJi4P/J5vP48WMYqbi4uPj4+JiYmKdPn04hH2mIi4uLiYlJTEyEqsbFxRkbG1+5cuXDDz/88MMPoYe3b98uyT7j9vD27du3b9++a9cumEs//vgjym379u3SnpJkH7guGXrv2LFjampq8ObAqTOvN4pJaJ01NTWvXbtmbW2NVgKsjdjYWIih9fHHH//P//zP1q1bt2/fvm3btq1bt/700087d+6c2tqeUcAM3rp1644dO+DzFDjo/fff/+///u/w8PAnT548efIkNjY2PDw8ISEhZpqAOAJY48mTJ8BuU8jq+fPn0dHR0dHRcXFxL168iI6OnsZ6Pn78GKoXGRmZmJgYHR19+fJlExOTP/zhDx9++CHMhB07dozLPttfB/p+69atGzdu3LVr188//7xjxw74FWbXmJBkn5iYmKioKKBgVVVVdXV1pHV+h61hZz8mpHXGcfz06dN6enqPHj2KiIig0+l0Or2pqYnBYDQ1NTGZzIqKisrKyk2bNv3444/nzp07T4Dh7MOhQ4cOHTp04sQJNTU1AwMDQ0NDY2PjKVTVzMxMX1+fRqPV1dU1NTXR6XQ7Oztzc3P6NIHJZNJoNGtra0tLy/r6+ubmZhqNxmAwJptPQ0MDk8lsaWlhMpkMBqOiosLGxsbCwmK66tna2lpdXQ36lJqamvb2dpgbJiYmNjY2+vr6RkZGhoaGkuwzZq+imWNgYHDu3Dl9fX14N+jr68OXRkZG8EHauEiyT3Nzc3NzM51Op9FoJiYmRkZGEGkb5raMTRyFGcWE7H0EAoG2trampmZQUFBwcDCDwQDeQexTWVlZVVUFWmcjI6MLFy4YGBicP38ept35WYYDBw4cPHjw5MmT6urq8I2xsTFUeFIwMDDQ09NjMBhg6t3W1nb58mVbW9vpWtVNTU2tra1mZmaWlpaweMCjarJgMpkNDQ0MBoNGozU3N7e1tVlYWFhZWU1jPdva2szMzCwsLJqbmxsaGuBLS0tLMzMzIyMj4AtJ9iH1J0yVCxcuXLhwAf48d+6cnp7e1q1bN23aZGRkZGxsrKend+HCBUNDQ0gzJiTZh06nQ63odLqJiYmpqemyZctWrVpFaXzeLCZ05oVh2OnTpzU1NdPT09PT06Ul8/Dw8PT0hPTo/1mI5OTk5OTkmpqaqqoq/HfXk9hYT09PDw+Paakkws2bN1Gev6eqb7yeEz/zQo+DJeedO3du3bolI2cSpJ15wbP29vYODg4QA3/WTtF/E1DsQ7HP9IBiHwqTBcU+FPtMDyj2oTBZUOxDsc/0gGIfCpMFxT4U+0wPKPahMFlQ7EOxz/RgNrMPEBDFPrMNFPtQ7DM9oNiHwmRBsQ/FPtMDin0oTBbyY5/k5OSsrCx3d3c3NzcPDw8XF5dnz549efIEJ8R/mJrTDZ1Ob29v9/Pzu3379vnz5/X19bu7u7u7u6Wll8E+xJoLhcLQ0NDAwEA3NzdPT8+EhITU1FTJgAyTXdVCoZDH49nb2zs7O0/E2m3MVY1hGEbwpy8qKiooKDA2NjYyMsrKyoIoKCjoBzyFqj0yMuLv7+/q6jpu0ZOCNPaBemIYJsk+t2/fhjQkd4fJso9AIOjt7W1vb79z586Y1EOxz+yEPNgHokNkZmZmZmbevHnT29vbxcXl5s2bT548iYmJIa7Aqd2E0dfX19TUdO/ePV9fX/Dz6O/vnxr7oGrA/w8fPnz48OGtW7c8PT2TkpKSkpJQYlI8rYmwD4ZhEGpLKBQ6Ojo6OjoSPeOlYcxVjZ4Si8VcLre0tDQ7O9vAwODixYtw0SMxGbGB0DRPT09vb2/Z5U4WkvVE/vTwpyT7PHz4kM/nEy8CIzVTNrOskUwAACAASURBVPsQp0pvby+LxfL19aXY5y2CnGQfWGYo7q+hoeHp06fFYjGbzcZHnTmmPBXOnTt36dKlgoKC4uLi4uLi8vLyxsbGjo4OaemlsY+k5OXh4XHz5s3W1la4MpjFYmESkUMmK/v4+Ph4eXk5Ozs7OztPpMnjsg+O43fu3Ll3715fX19bW9sPP/zw/fffw/0NKCUpqJiWlpaamtq4RU8KMnZeULok+9y4cYPH40HAsDFDYo4r+/D5fA6Hw2aztbW1dXV1tbW1KfZ5iyAn2Yc4twQCgaGh4dmzZ3k8nuRtEFPwOQZ/ovz8/KysrMLCwsLCwpaWltbWVmnpZcs+xDqAjAarmsvljoyMoJc56bLWCbKPWCz28/Pz9fV1d3e/ceMGPoFoYdJ2XvABqurl5eXj49PT09Pf379+/fp169bBXSPEcnECB8FClV3uZCFj5yVN9vHw8BgcHORyuUKhUHL/i4/HPpAzm83mcDiGhoYGBgYyLrzEKfaZfZCT7IPewEVFRaWlpb6+vn5+fihzXIICJoVNmzb98MMPAQEBvr6+Z8+eNTQ0rKqqamhokJZ+glpnsVhsbm5uamoKt1NBD4jFYhTJULL+stknPT09LS3t5cuXZWVlHh4eXl5eE2mdbPbBCVdx5uXlpaenHz9+/LfffuNwOHw+H3Z5xNcAfHB2dp5g6ROHZD0hfhsqXZJ9tLS0kMqPiClonSHunYaGBsU+bxHkwT4YhsEkE4lExcXFeXl5t2/f9vHxAZlImsZx4ti8efOPP/7o4uLi5+enq6urq6vb1NQEzDImpLEP8TZOHMcFAsHVq1dNTU2DgoJCQkLOnDmjq6uLE27yIFZ4IuwDF7rX1NSUlZV5eXn5+vpO5D4p2dpcVFWxWJybm1tWVnbkyJHffvsNbltD7YIPUGehUOjp6Xnz5s1xi54UpNUTuksoFEqyz5kzZ2BukPazE2cfpDNKTU1NT0/X1dUl0g3FPrMc8j5xP3r06OHDhyHcjGQp0p6SDT09PQMDg66uLjqdHhQU9OjRo9TU1IKCAmnpx915oZUQGhoaEREBX544cUJVVXVwcHBoaEhatWWzj7+/v7e3t7Ozs6en5759+/bt25ednZ2YmCi7dbJPsuEbExMTMzMzHMdHRkZMTU2NjY1RvFfUFognC5+9vb3lxj6ScZ0hHhuRH0mK50nJPvDOSE9PT0xM1NHRodjnLYK8d15Hjx797bffmExmc3MzTpiaCFM4dD979uyZM2eYTGZbW9uDBw+Cg4NzcnJycnKkpZehdSbVGeITQ5WOHj165MgRHo/H4XAkVaQTYR8/Pz9/f3+QOw4cOHDgwIHExMSkpCTZrRtzVaMKwIfLly+bmZlBJxsbG1+6dAlYEh3eoQeBjNzd3WGkphGS9SRuu4iyT0RERERExPDwMJDOmJdtwIdx2QfNn6SkpIyMDC0tLYp93iLIlX3wUcsUXOJ193sA27o7d+7cvXv3/v37Dx48wGWymGzZh7gMYK908+ZNd3f358+fx8bGSiablNYZJS4rKyssLCQVNyakyRTEm62ys7Pz8vJI9cRGj72nUM8pYEz2Qb8S2cfd3R0ML5ydnXEcR7ehIUycfZBJAURNe/78OZFucAIB4RT7zD7Ig33QAuPxeMXFxfn5+RO5lWniEAqFfD7/7t279+7de/DgwcOHD4l3S0liIifuGIYJBILs7OyMjAyQFJ4+fZqQkDA0NDSmomoiqxoVxOfzS0tLi4qKJiLoSa5qYgVEItHIyAjcdESsJ5vNnnI9p4aJ77x8fHzc3d09PDz8/f2Hh4clGzVZrbNIJGppaWEwGImJiRT7vEV4A54WkpL2tGDiWzbZsg8xnzEFHFzidhd8wqsabUZEIhFkMq4MKEP2keT36arnFDDmmRexGkQHC0gg7Q0xQfYharIAYrGYYp+3CPJgHzj0ResNn+4rBklbjHEv2x1X60yqLbEUIAvispnCzmtSkG1Hg+pJyhmkyynXcwoY09aZmGDMW0NJlj7Ex/GJyT4YhiFbVtk1pNhntkGusg8cwYxp4vH7QTpXljGxZJy4j6lOxkZPhfGxXtdT23kJBAKhUDgR5Zc0OxpSMpKj3O+p59QgTTsO1/Whb1ATiPca4hLECh9ksw/Jj2TccafYZ7ZBTuxDcqTAMGzaVT/46GsQH0+2GnfnBQIFLGBJ7QkSOtA3+CRXNVEqHJeIZcg+sIZnrp6Twpj6KZJASnL7QJdEjylm4uOxD4luZO/3cYp9Zh/krfeZifGGWYjoDD5MQfYBoWxMsQLpayQx8VVNPP+euAA4QdmHmPPvrOfUIMMyQFrv/U69D/oGkazs2UWxz2yDnGyd8deNg2UskqlBUsUgI/G4eh9UW6JKZbpWNclUZ2p+XghIfJCs55jtkjP7EP+UlHaJwssUvEyJs0j2GBHTUOwzezCJu0w1NTUzMjIgdsyYgNAZ+KjhP2nnBR+ISpbfU+8JYsxyk5OTX7x4UV1djbwxSD4WqNUTqSSsASjIxcUFIldMob1IGkKPQCbIKwK0J7IXjIxyx6znmOWO216csPJRlcBzbVyVv4z2SiYYGRkZHh4OCAjw9/cnNRCXYJxxC4W6Xbt2zdHRcc2aNcuXL8dHN9rj1pbCTGBCso9QKNTQ0DA0NExMTMzPz8ekAKJwEScTUYECIA62tHymC9LKBdmnqqqqqqqKtFqQBynxtFha/qQTXwzDPD093dzcJttenKBAJS0hDMNcXV1JsTgm215p9ZRWruxeJRYBOUAmEA8A5SY7B2ntJQLYh8Ph+Pr63rp1i1RDdERAZB8YFBnlYhhmZ2d39epVZWVlFRUVjJJ93igmxD44jmtqap46derMmTNnzpy5KQWHDx8+cuSIr68vTG43NzcvLy9/f383NzcQi+A17unpCcZm0vKZLkgrF6IxWFlZmZube3t7e3l5QbhFT09PHx8fSOY2CnCJGhP+/v7wLNCur6/vkSNHDh8+PNn2ent7u7q6enl5QdwfDw8PDw8PNzc3sB48ceLEiRMnvLy8II2MfKSVK62e0sqVlr+npyds2Tw8PKBuUHnouqNHjx46dAhSuru7y+g3aeV6eXmRinNzc3NxcVFVVT1+/Livry+IV5A/lA4fUH28vb1llAvJ9u3bd+DAgRUrVqioqOA4LhKJpvcAhMLEMdGdF9zjbmxsbGho6CEFBw8eVFVVvXHjBswD4jJ2dHT08fGBSebp6Qke3tLymS5IK1dfX//cuXPm5ubm5uaurq6Q2NvbGxaem5ubr68vzH5ETNLyR5Pe09Pzxo0bqqqqBw8enGx7YR8EsgOsJViZN2/edHZ2Pnbs2KFDh2C5wqqebHul1VNaudLyh7WNqA2edXV1dXd3d3JyOnLkyK+//gopvby8EE9NvL3wqzsBrq6uLi4uhw4d0tLSgtHx8PCAbvH394esbt26BX2CnpJWrru7u7Oz8+7du3/55RclJSVFRcWZX18UZGEc9sFGt9YaGhpnzpxJTExMS0uTlpik60Gf3d3d/f390aYGG8uWbyYwbrmohqjm8Cufzw8LCwsLC2tra+vs7JRdCiahB51Ce9GpOZCd5F4J/S9DSSG7XMl6jlsuCWAfgDZNQqGQyWTSaLT09PT4+HicYEgxriXBxMtFM5C4rywqKkpJSSkoKCgrK+PxeJM6wXBwcLC3t1dUVFy1ahWfz6c2X28Q47APmhMaGhqnTp3Kzs5OTU2V/QhJO0DUMuAzc+IuDRMpl/Q9EsKjo6Ojo6N7enpkxEjEJHQxEy+XCGL4dxC7SJUhWc1Ig7RypdVTWrkTB41Gq66ufvr06fPnzyf+1NTKhafAJbWwsLC4uLigoKCkpISURgYTQX9aW1vfuHED2Ad7XW9NQc4Yh32QlaCurq6WllZubu6LFy+kJcZGzViI72oMw0CoJv40Q+bOJEgrV0wIZ0Vcz0RNc2RkZHBwcHNzswzZh9RMlPNk20vMB/YIJAbHR6UJscyo+9LKlVbPiZQrCVDrQnPq6+vr6+uzsrLgbhK4rgMnyFaTaq+MojHCERuO47m5udnZ2YWFhRAvYVLHdk5OTnZ2dqtWrVq+fDk2pUi+FKYLE9I6i0QiTU1NDQ0N2fY+uBRTVNickzyzp1rhSUB2uSS7W7Rc4UNERERYWFh3d/e4so+kocoU2osSgPKVmBtxJcumbGnlSquntHKlgcgagLq6urq6utjY2JSUFPT9RChsUuWiyqMm5Ofn5+XlFRYW5uXlkZozLoXBzmvlypVI9qE2X28KU7Q2JB5UE7Un+OsnoJASzkpQVvjrJnbIUo5EB+iFhv4f809iBdC8hzxBqUlsBemDeCzvLfgcERERHBzc19fX2tqKskXVJoV2BqCl7u7u7uXlhUoZ02RRWhx1Dw8PotUCqhjJzoXU8/DB3d3dx8cH6VCIdIPGgtheYiagoiYe0pPqRtQToT/r6+tramoSExNJOy+SBlBS98ThcOCDq6urr68vsY1IeiK1jjhq+fn5ubm5+fn5RUVFxM4nWl0Sw84SM6SsDWcPpsI+kssYZjxxLCHuDHz29vZ2d3cn7gJwgk4UHiTOGJLTNmlzhI36N+E4zuVyiQ+S8ocTaNjtEzOBZ9EKJJEmICIiIioqislkop0XyS0A9qQoaDGRDVHcUtIywHF8eHgYJ5CXZE96jNqLjwlQ+pKqilTLcCKGvidlTvJoJV00AgdM8JnkqiIjUlJdXV1jY+OzZ89SU1OhURDKHiVAhaIvScfbyOqaxKdIe01qOAxxYWFhfn5+SUlJQUEBqTegtpIBs9H8pNhn9mDq7MPhcF69ejU0NATxg3Ecp9FoNBqtsbGxqakJHoTpcpNggw/GacAgAwMDfX196HuBQFBYWJibmzs8PDzmJXNQysDAABQ6PDwMN+fk5eXl5eWBDrK9vb23txfSe3l5eXt7E1eRSCTicrmvXr0aHBzER8OSjYyMZGZmFhUVDQ8PCwQCDocDep/w8PCurq6Ojg7iyVFbWxt8g+M4i8Xq7OwsKioqLCysra2tq6uDUuAkmNh7GME0EWUlEAiqqqoqKirEBMtAIvtA73V2dnZ0dBDXSXd3d0tLS1lZWU1NDdG4GfoZLWOhUIi05miJVlZW1tTUMBiM9vZ21PM4jsM5PU5gBwgg29/fz2Kx8FGGxTCsp6enu7sbBrGmpoZGo6WlpcGZF2L/vr6+zs5O6FuoSX9/f1dXV1VVVXl5OU4gF5DX0MsDccTAwEBnZ2d5eXlubi4usXXNz8/PzMxEOy8AivZfUFBQWlrKYrFYLBZwFlEmothn9mDq7DM4OAihy4FB+Hx+U1NTfX19e3t7bW0t/roNvsfrXkXwauru7u7q6kJ7AZFIlJ+fn5+fPzw8jBiEOG/gz1evXrFYLJjZzc3NNBqtoKCgqKgI1JC9vb0grQiFQrDWwQhR4rlcLp/P7+zsHBoaGhkZQfG98vLy8vPzBQIBoryoqKigoKDu7m6IP43q0N7eDvcUwjpsa2sD7qutrQW/DbFYDJaB8BRJt41kJfiztra2trYWbtQTj94ySrIX7+joQCUCD7a2tnZ0dFRVVVVXV+MEIQ5kTFjY0JDu7u6enh4k64lEooaGBjqd3tDQAFH9IRmGYWiMgPKABfh8fl9f38DAAHE7DHnCZwaDUVlZ+eTJk4SEBOJsGRgYYLPZ4LwObens7Ozu7i4tLUV8AT/5+vpCX5G8c+Adk5OTA6da8LaAV5RIJAJ9c0lJSWFhIUawe4bHCwsLi4qKWCzWq1evcAkZkGKf2YOpsE95eXlFRcWhQ4f2798PfJGbm1tUVHTmzBltbe1nz57Fx8eXlZVVVFTAs2BPDNNaIBAIBILg4ODAwMA7d+4EBARAEWZmZpaWlk+fPo2Njb1+/bqrqyvphmUMw0pKSsrLyzdv3vzTTz/V1tbSaDQ6nc5gMOAE5O7du35+fhCJGVYL2KdBDvX19VVVVTo6OhoaGjExMZGRkfD9uXPnzp07Fx0dHRISArISTOWIiIgnT560trZ2dXWBVUh8fHxsbCxYJ8KCv3379t27dzMzM7Ozs2traxsaGiAl8swSi8W1tbXFxcXXr1+3sbHBRp0hRCJRT09Pb2/vF198MXfuXOBxqDNY5QJxNzc3t7a2njp16uTJk9AD6enp2dnZQUFB9+/fhzsUS0tLX758CSvZ1dXVx8cH2lVaWpqTk3Px4sXz589DTTIyMl68eGFgYHDu3LmYmJjHjx9HR0fHxsZCP6O24zje3Nzc0dGhrq6ura0dEhISGBgIORQXF5eWll66dOn8+fOw2isqKhgMRkZGRlxcHI7jIyMjWVlZ+fn533///bp163p6ekAU7enpsbW1tbe3B9PTpKQk0B6Cjgz1J4DFYnV3d8MNIs+fP09KSnr27FlsbCxxywY3R+bn50NsbIBAIHj8+HFISIiPj4+fn5+5ubmVlVV/fz8IszjFPrMPU2Gf2tra6urqnTt37t27Nz8/v6CgIDc3F25TMjQ0fPz4cXx8fG1tbU1NDT565kXSZYSGhoaFhQUEBNy6dQtev2ZmZlZWVjExMeHh4devX7ezs8NHrdfQFIGI9D/++OOOHTvgBd7e3t7Y2FhcXFxUVHTv3r27d++mpaUhP1jYicC7sampiclkHj9+XE1NLSIi4vHjx5D/5cuXTUxMgoKCwsPDQfMK6+rx48ePHz9ub29HN/8kJCQkJCRcv37dxcUFVjuwT3p6ekZGBtFnFQyLgWfr6+sbGhquXbt2/fp11HyRSDQ0NNTb2/vll1/OmzcPJAVYIUT26erqamlpOXnypLq6OmwSc3Nzk5KS7ty5ExQUZG1tfeXKlZqamtLSUsgW2BYUUiUlJS9fvjQ2Nr58+bJYLObxeGlpaQkJCUZGRoaGhrCvhHM9fNTqz8vLC+pQW1vb2Nh45swZTU3NiIiI0NBQGIKSkpLi4mITExNTU1Pg6Pr6+tra2ri4OGSHAWm+++67H374obm5ube3F9jH3t7ewsIC7o9OTk5G8fnBLwfHcbTXHhoaYrPZYF/2/PnzlJQUuAODOBtB3iwqKiouLsYJmqmoqKjY2NibN2/eu3fP0tLS1taWw+GAbE5pnWchpsI+w8PDHA7n2LFjx44dKywsTE9Pd3V1tbe3f/jwIbAJm80Gm3d4HN6r+GhEOxzH6XR6d3f3rVu37t69C/n/8ssvO3bscHZ2vnnzZnBw8KNHj4gVgAeHhob4fD7cHdjY2Aj7DgzD2Gw2l8s9efKkqqoqpAfOgvcqPiqxc7nc8+fPGxkZAbN4e3vfvn177969e/fuhXuNm5ubQWOFYVhYWFhQUBC8vYGP2Gz2wMDAzZs3vby84D2MjPfd3Nzg7h189K4+pP1ls9nDw8M3btyA+xtEItHg4CCfz79582ZAQMDKlStXrFgBuwyQO0BuQnpiDMNu3LiBmAu+KSkpyc/Pt7a2trS0ZDAYjY2N0GQ444NnWSwWl8t1cXGBcnEcT0pKio+PB63c8+fPU1NTAwMD79+/j4/Kpz4+Pkh3zuVyL1++bGxsHBISEhQUBEXDbUJOTk4oTxqNVltbm5SU9PTpU8gHbvKB25z7+vp6e3tzcnKKioqSk5Pz8vLa2tq6u7u3bNmyc+dOoAOQJYlqnZqamtra2l27du3btw9EQgcHBxcXF6QmB/aBQ3c480KPJyUlZWVlOTg4ODo6bt26devWrd3d3f39/cR9GcU+swdTYR94TR06dOjQoUN5eXnFxcXW1tZ2dnb3799/9OgRm83m8XigTUS6DHd3d2z03FQkEvX393d2dt69exdOW4VC4Z49e/bv3w+r9MGDB5GRkcTZBs8ODw8LhcItW7Zs2bKlqampqakJOUbweDzYKRBleDc3N39/f6R5EQqFZ8+ePXfuXFRUVHR0NEguBw4cOHjwoJOTk5OTE2zloDjYeTEYDHTm9erVKx6PBz5TkKGXlxeIdTdu3AgMDAwNDSXpbmCrJRKJYMUibf3w8HBQUFBAQICysrKSktKrV6+Gh4cR+yA5EeQd6BNs1HF8ZGQEPAyuXr1qa2vb0NCA7oyGfobPHA6Hx+O5urq6ubnBg8+fP3/x4kVDQ0NtbW1ycnJcXNy9e/eAfXAcBwc39KxIJDIyMrp06RJYHsD3QJFOTk43b96E2oKUBLIPMDK8mb7//vvVq1eDhh60cpmZmampqT09PR0dHVu3bt20aROqM9j7YKM2Dc3NzQ0NDbt27frll1+g9xwcHJycnIizMTc3FyYeWBsiW4ecnJyMjIwbN27Y2dnt2rXr559/7urqQicbFPvMNkzR3kcsFsMuBg6b4KjIxMTk0qVL165ds7W1Rec+cOZF2nlxuVwOh+Pv7//w4UNIc+HCBV1d3b6+vv7+/g0bNmzbto3NZhNvm0Nbd5hV9fX1TU1NaLV7eHhkZWWBFwh6E4JbJmoChmHm5uaXL1+Oiop68uQJOEzCqTyTyezr67Ozs3NwcIA8IyMjQ0NDQfYh5gk7FJi1CQkJycnJ4CStra2tpqbW2tra3t7u4+MD2m5Urp+fH6xt4LVnz54FBAQEBwcvWrRo8eLFsJPFCedWOIFzYS8G+6nOzs6BgYGRkRE+nw/7kStXrpiamkJ6GeVCB7JYrBs3btja2pqaml65cgXp+8VisZ+fH2JVSGxhYXH16tVHjx4Rdz346zxVXV1No9FAqsJHD9pwHP/Xv/61cePGzs7Orq6uoqKioqKi/Pz84uLilpaWrq6uI0eOHD16FHIgnvERueD+/fv379+3s7NzdHQ8cuTIsWPHiOZgBQUFYG0Iu070ytm1a9f+/fvr6uoqKir8/PxcXV3pdHpjYyPqE5xin9mEqcc2PHLkiKqqak5OTnZ29sjICJfLvXjxopGRkY2NjY2NzbVr11xcXIiyADFDDoczNDR069at27dvw1Gunp7exYsX29vbWSzWtm3bNmzYAJGlSMY+YrF4x44dP//8M5JTcBwHD+nk5OSMjAxkVgdnT8RYiziOw/v88ePHoD/28fGBtQQ2zc7Ozo6OjnDcA/Y+ra2tDAaDWHO0u8EwDKzsQKrS1NTU1dWFO+3Qjg8fpU6QBKEaUVFRUVFRICfOnz9/wYIFsNeA9ECIRLse4vrs6Ojo6+vjcrk8Hg9O5SBOCCplzHKhB3g8HpfLdXR0tLW1tbCwMDExQT2DYZiHhwfiFHj26tWrVlZWgYGBISEhxJNH8DKHlDQarb6+/sWLFzExMTjhXH/z5s1r165ta2vr7e3Nzs6G48j8/HxQQh84cEBNTQ14CuQ1NGr46DHcvXv37ty54+joeO3aNbh9WywWo5NBlCGcxyPs2LFjz549VVVVNTU18E4CKxBiYDaKfWYPpsI+oEZRVVVVV1eHs8+MjIzk5ORLly5dunRJVVX11KlTPT09sGch2ToDYPdx7949dOalqqqqqqp6+/btW7du6enpaWpq4q9b66Gz8J9//vmXX34B9oE9hZqamqam5sDAQHd3N6SB1QJRJojlGhkZmZubh4WFRUVFDQwMDAwM2NraWlpampubm5mZBQQE3L59G1KGhYVFR0e3tbX19fWhvRvstkCTjeO4lZWVlZWVn59fQECAmpqalpYW7AGR5hgdITs5OSFe6OnpYTKZVVVVL1++XLx4sYqKSn19PehucBxHjIkAuUFvlJaWFhcXa2tra2lpmZqaXr16FVgSx3GhUCijXKFQCJx74MCB48eP37t379atWy9fvqysrEQSlp+fH/Fs6MqVKxYWFmFhYZGRkUR/FLBphHcGeJkmJSUlJSXBU3w+n8/nb9y4cf369V1dXb29vS0tLe3t7WpqahCjx9PTs7KyEiIlgFwMcQuRiWN/f/+rV690dHT09fUhpoe9vT1ovhBJ5eXlZWVlFRQUFBcXE41FQQPg5eV1586do0ePnjhxAiyPUOVxin1mE6Yu+xw7duy3336DnVdKSkp6evrly5cNDQ1VVVWPHj0Kp7aSugykT+XxeLdv3wb2wTDs+PHjx48f9/f3DwgIMDAwMDQ0BKUJugsMH+WUn376affu3dXV1XCmho8yF5g+wjew/MCCDlgDx3Eej2dhYWFgYBATE/Ps2bO2traBgQFLS8vr169fuXLFzMwsKCgoLCwMno2MjIyKimppaQFbG6SBgluAkXRgbW0N71htbW0NDQ1gH4gagXpPKBTC9e2QT0dHR39/f0lJSU1NzaJFixYsWMBkMltaWuDmGTc3N1dXVzHBNRT2j1BicXFxeXm5pqamtra2ubm5paVlXFwcnN/hOC6tXCDu2NjYZ8+enThxYv/+/bdu3fL19a2rq6uurgahwM3NDenpoGhzc/OrV68+fPgQdseoY4nSSk1NDZPJjIuLA08LZCSxdu3aLVu2tLS0dHZ2wqnf8ePHNTQ03N3d79y5A2bKkNLFxQXtjiF/Npvd29urp6enra0NUq2dnR3IZWgnnpGRAWYfWVlZOMGO2dnZ2dra2s/Pz8vLC2KSwe6PaMdIsc/swdT1Pnw+XzR6YTFoJbhc7sjICOiAcMJcJOp9kHIRvceIfg8QSVMkErHZbPx1J0lIAIdZRPt95KgBxsTIJBfHcThPITYE6An8M5AegcfjCQQC+An+FwqF4eHhYWFhnZ2dbW1tyH4PG724DnLj8Xig9BETbrbBR+UXKAISg+kdqgbUH5TKxA84joNtFGodHJYTmwCKWKgnqHhFo9H5ZJcLJulgzy0SiTgcDoZhRH8rYl/B48jcgeQHBxXj8/n19fWVlZVJSUkJCQniUUcw6JChoSHi2oaJAVHiccIeDeKfYQSLUKgS9C3s6DEMIzpwiESisrKytLQ04CBUBHQjnI3yeDw0IiQvM4p9Zg+mLvvAagfAzIAhHxoaQjIIcIEk+0B6oi8FrAc+n4/s7nCCvgaJ5chwnhi/CuYrWsDoKbgvHBv1ySTu4JAIBl8ODg6SbPmfPXsW3tH8egAAIABJREFUGRmJfNxRWSQ3S6BaWFSIzuAkHmVFOrkjelGKxWKoPPwpEonAUoHozAX9jMxh4BEejzc4OIjSyC4XOXnAg1wud2hoCDgadRra8SF/BagesggnZog6oaamhk6nx8fHg9YZ9SGwAE6QVoDsYF8GLwxITNQiocrAW4TH48FLiMjs8FROTg4c/BUUFBDfRqiTBwYG+KNA3Uixz2zDFNmHKA7gEveIojcnPCu58yIuGzSnUSYw1dBrmSgBEXMgHmTAGxUjxDOHPQI6P8Jf99smyVykCoDsExwcDLbOxAqT3uc4YTUiz0ZYyWIJl1pcgryI/YD0L8QIG8QERKBzQBA/kb2ytHJxCQJFLIOP2igRZR/grDFLx0aB43hNTU19fX18fHxycjKSkhCpkaLc46+/byA9abeI9keoaCIl4aPyIByi5eXllZaWogYi9keiH2ojcQpR7DN7MEWtM/FX0vyQjNEteaqKZhL+Oh9JW2ySzxK/RDmQFhjR4wG+J73Gif+jfKAIsEgk+rijBMQpS5r6kBuKWYMeIb6ccSkcBD8BC5D6gdRG+JPkeo7slccsV7KeOIHdMAwDv3ziqTZOGBqS1wv6v7Gxsa6uLiEhISkpCSWQjChCzBYNE7Lthjoj0kTEQexnEBhRGnCzAA4itpTYJ8QoaMQ+odhn9mBCcZ0xDNPS0oL7vOC0YlJA/tOyyUWyXFKYhckCNKlo6k9wqkGysLCw8PBwsJebbLmTbS9R5oJLNSbeUURMtr1ED1io8wTLRZxVX18vyT6ACfY2BM/HJzk34Ky9sLAQvEwn+CC0FNhn9erVcKcFRUBvEBOK6wyyz5kzZ9LS0jIzM7FJAjSaxLcQ7BekpYcXHfEtLSPEjAyABpc4vcQyr47DRjUIIpEIPCdQdIsZbS8kg50m+JrghI3nzLUXJ+xYwTcNVVhaPbHXBVWIrJqQkJCYmEjc8cnOhyiKwq0YaJrJALH0goICkH2KioqIP42bA47jDg4ONjY2KioqcKcFRrHPm8NE7/PS0NBQV1e/f//+w4cP6yaJK1euWFtb19bWglMiKAsaGhqkpafT6TU1NXV1deCYXlVVRafT4Yh9UjA1NTUxMWlqaqqqqoL4O9XV1U1NTdLSg586VM/JyQksGHNzc2e6vZWVlQ0NDbCS4ey/pqamsbFxpttbVVXV3NxcUlJSX18PHvPV1dUVFRWyWwe+XTQara6uLj4+PiEhAW46Rk2AsCHV1dXScgBvD8jKwsIC+kpGepS4fhTBwcEhISHgJQvfQAKUeEzU1NRUV1cbGRkZGxuvWLFi5cqVMLenJmlS+P2YEPuIxWKw5b179+6jR4+qJ4nLly9bW1uXl5fDvESzX1p6tHhoNBpEw6qqqkLTeuIAL2eIgwPzEqxgpaWHtfry5UsajQZm0NnZ2eC/PqPtbWxsLC8vh8/GxsbW1taIDWe6vVB6Q0PDlStXrKysgChltw5lW1NTAxEwbt++7efnB8MExUHpMnKorKyEfMzMzK5evVpZWQlcKbvc6upqyD80NDQiIiI6Ojo8PBzRCnS1jBzq6uoqKiqMjIwMDAyQ3oeSfd4gJnqjzunTp+FGN2dn5xeTBNitglcU3KGemJiYmJgoLX1KSkpSUhIk27Bhw6ZNm9avX79hw4bdk8S+ffu2bt26f//+3bt3//zzz/DNL7/8Ii39nj17tm7dum/fvt27d3/88ceffPIJ+FjOdHsTEhJSU1OdnZ29vLzmzJmjoKCwa9eu7du3z3R7Dx48uHv37hUrVixduvSjjz766KOPZNcTjU5iYmJycnJKSgq8jRwcHGxtbdPS0l68eAF2z/BBWg7JycnQOSkpKVpaWmfPnk1KSoKOkvFIcnIyJEtNTYVYImA5nZqaCsWh3paG1NTU5ORkDQ0NLS2tZcuWKSsrU9TzZjHRu0y1tLROnjzp5uZmb2+fNEno6+vDDEtISHj+/DkoKdFMlQR4Y8fHxyclJX3//ffffffdjz/+uGnTpl8miX379u3Zs2fnzp0HDhyApbh//35w1BgTe/bsOXz48K5du/bs2fPpp5/+7W9/A93zTLc3JSUlNjbWzc3Nzs5OQUHhj3/8408//bR///6Zbu9PP/20d+/eNWvWrF69+s9//vOf//zn2NjY1NRU2a0DuoT1DHEC7O3tbWxs0tLSUJOfP38OwzcmkpOTnz9/npiYmJ6erqOjo6enl5ycHBMTI6NE+IB60tnZ2dXV1dPT09XVFVgJfpKNuLi4pKQkVVVVXV1dRUXFFStWkCY5BTlj/DMvDMNEItHp06fPnj0LkbQmWwZYlEmeIo/7oEAgOHTo0IEDB0pLS2tG/SomDqKKFBnFyAayYAJpq6uri8lkTrbcybYXfkpPT09OTv7ggw8UFBR4PN6Y12bIxhTai+N4ZGRkZGTkf/zHf3z88cfjDgqxCBzHGxoaGhsbQWKS1DrLzgQf9dsgacplAJ21gb65rKwMPDYwmdeHkQCS2sqVK5WUlCb1IIVpxyRkH7jPa9y7TCVBjDszkfGGZQPLD3YHsGOfbLm4hKXixPH9999v3ryZyWSCteGkMNn2AlJSUtLS0hQUFBQUFIhGupPCFNobFhYWExPz0Ucf/fWvfx33WdIBE+hcSCfuxDTjZkWyCJ3II2KxOC8vLycnB+JqTrA4lAZ8VleuXKmsrEz8noL8MXVPC1zihl8QlEj34YCnBXgwEq3OiEOOvW4KTFyu+/fvP3jwYFlZWXV19e9q6MSApvLGjRt/+OGHjo6OtrY24mkuqf7Y6/ZsOI4LhUIPDw/iDXmkwPjIXJDYUrFYnJmZmZaWNmfOnDlz5oC3qhzai49G/ICdF3FQSNVGn5ElMYZhtbW19fX1sbGxiYmJxJSSpuFEG0WiEQDYKJEmEv669SbJEhVO3CG6GDGuM/468ZHmGxIJHRwc7OzsFBUVwd6HwhvE1O+0gOVBcg4c8zVC9GNGSxTHcXAjIs1IdFEX/Ll79+4DBw5UVlaiqMkzijHZBydY64Lhr+SmhjjRPT09fX19iZ4KqFskJRroRoFAkJ6enpKSoqCgAOwjeaHQDEGSfTCC5xROWL0kS3GRSNTU1ESn01NTUyHOEU64qow0rBhGvgER/nRxcUG7VMifFNQJPYvMdkD2yc3NzcnJQeyDEcxTJf1yiX/euHHjxo0bKioqKioq1M7rDWLe012/6zZB/HW6QVIPspSD2eDt7Q2rkeh5SHwQ+akTJyhkcuDAgV9//bWysvLly5e/t7kTgDT2Ia0clJj4XsVH1UYuLi4oqg5OcBpAiZHfNnEpQmxG2HlBBBI5tBeXLvvgEnefAogOYnDKjrxMYbhJflXYqNsXcp0lcjfy8CD1JImASBwBUaVQhA2iuI2CLoDQRJSqxIQYQMuXL0c7LwrThXlPd03q39R3XsS3vYhw3x5aqOjt5+zs7O3tTdRKEj3CkDiAtl3ENQBHUWAe8vt7ZyItxcdiH8lJTHRTgFWK0vj7+8MdVWJCWBlpxSG3pqysLKT3ebPsA2bZkpEGAERmYTAYdXV1cMJFahf+uqU1UeZFEIvFpJiKRPd34taP+JnP55eWlmZkZMC9XSg3lDkppAZOcLXHcdzOzs7FxWX16tUrV64kNpPCuJgsucwI+8CAmZub29jYwP0Nurq6Ojo6ra2tbW1tPj4+Li4uFhYW5ubmDg4OoARBO6/a2trGxkZVVVVNTU1LS8srV65kZGSkpqa6urrCZb4eHh6nT59WV1fn8/lw5nXo0KGqqqqysrIZ7FdCS3EJ9oEY5qampsbGxhoaGjo6OqWlpfX19fr6+hcuXIBYfxEREejOKRcXF+Q5CbEQnZ2dPT09UQxmiIxDo9EWLVq0fPlyuEMmNTUVyT5T1jpPAZLsc+3aNVNTU3d3d0dHR2Nj4/Pnz5eVleXn50M8uYsXLxoYGDx69CgkJKSioqKxsRFOxGG/BtGgXVxcvL291dTUtLW109PTc3JyLC0tL126dObMGXV19aqqKrj7DMdxX19f5OcF92rAiaG6urqqqiqbzWaxWK2trc3NzTY2NhYWFjD30tPT4drbwsJCFos1MDCgrq6urq4OQf69vb1dXV2dnZ1v3LhhZWVlZ2cHcewgJADIPkpKSpTeZ+KYdt75XbKPWCy2s7OztLSE6MhgQ9HW1tbW1gY+ChYWFpaWlm5ubtevX4do5/ioZ1BdXZ2WltapU6cuXrxobm6emZmZkZHh7Ozs4eHh6Ojo4+MD52vw/t+/f//+/fvB32JmO3i0pbgE+4B+4dKlSyYmJurq6pqamuXl5VVVVXA/D6wWiBwIz/r4+Hh5eaH4NR4eHv7+/h4eHhCrFNZAU1NTc3PzokWLli1bBrdupqamgtb5jbOPiYnJ1atXHRwcXF1dgX0KCgoKCgqOHTumpqYGkSfDwsKCg4PBHj0uLi4+Ph7ae/36dVtbW19fXzc3Nw0NjdOnT+fn52dkZJiZmRkZGZ06dUpDQ6OacPcZ8XwQdmHe3t5ubm4Q63JwcJDL5TY2NjY2NlpZWV29ehVSgta5rKwM7r8eGhr67bffTpw44ePjA5cF+Pj4uLq6uri4QODKO3fugP/tyMgIRO9WUlJSUlKSTw9POya7yOVf4gTrMxX2gSB1CQkJsN5wHL9y5Qq6IwEAseXb2tpaW1shGimO4yKRqLOzs7W1FW7vBIs1XV3dM2fO7N27d8+ePfb29teuXYOY4ZAPWNBVVFS8WfbJzMzs7u7u7e2trKwsLy+PjIwMCgoChvX19Q0ICIDv4VmwgsNxXCwWR0dHP336FKK+bt68eevWrXCLqbW1tb29/WeffTZ//ny4Awv6FthnZGTkDWqd6XR6bW0thHyE+85SU1NjY2PLy8sLCwuBHeBGxpqaGhqNBtahOI6PjIzExMQ8ffoUqPPy5cumpqZwG3JXVxebzYZwqHCXJOzviOeDT58+jY6Ohs9379718fFpb2+n0Whwa6C5uTnEzxeJRDmjKC0tHRwc5PF4MNMgJsG6devWrVsHezpokbq6up6eXmJiYlpampWVlYODw6pVq8DacJbsvGZIuJAz+0w22ynuvHg8Hpjkwx7bwsIC9hT46Imso6Ojo6NjS0tLa2sr7MXg15aWlsbGRpFIxGKx4uLi4uLizp8/f/78ebiNwNbW1sHBAeInwLTYu3fv/v37a2tr36DWGWKY9/f39/X1lZeXl5WVQewxiHzs6+vr7+8PUgCoJ9zd3VGcndjY2JiYGLjvcOPGjVu3boV7HWxsbKysrBYsWDB//nwk+xC1zm9Q9gFfKtAWHzhwYM+ePTExMbGxsXCTMsRafvr06ePHj8HDMykpKT4+HgK2QntxHBeJRFeuXLG0tMzOzs7MzOzr6+vu7obei4yMDAkJgdLBZBk+P3v2DN2N4efnd/v2bQaDAf2fnZ1tZWVlYWEBNQRLn9LS0vz8fLidqaGhAQarp6dn/fr1a9euBTsPOHk8e/astrY2eGnAzFRWVl6+fLkcundGaUVu7DNDmAr7AOP09fV1dXWdO3dOX18/JycHRdgFCzR0LxWO40gWwEc1f8HBwZGRkba2tk5OTgMDA1wu18zMzNzcnM1mDw0NrV27dsOGDXDD5759+/bt2week9Pf+rFaio+ldcZx/Pr1615eXiEhIaGhocPDw11dXeCb/urVK6FQaGVlZWlpCSmRnks8ejGOtrY2aEDS0tICAwPv3bvn7Ozs4uLyxRdffP3113AfeWpqamZm5nvvvffee++92RN3BoNBo9HgPgm4mxgc04uKiqqqqsLCwp4+fers7Ozk5NTQ0ECj0eLj45ENKovFgpjw58+fh7tGIc8bN264urqGhISEh4ezWCwWi4WPyomk2Ntnz541NDRMSkpKTEwEKRulhFuJRkZGSkpKsrKy4FIdeAq8zOCyoLa2tvb2dogcBGep2traZ86cASc1uOl0GtnnjZPL28tEUz/z6uzs7O7uBvYpLy8vKCgAaQWc0UHXA8sPYgyiQKs4jsNNeDAP2Gz2q1evYFcPO7INGzasXbsWIvvu37//0KFDcPfLjHXCay3FJdhHLBbz+XwfHx9nZ+ewsDC4ZZDFYsGtOCAJQtQYDMMEAgGKr4zOaHR1dTU0NDIzMxMTEwMCAgICAkDFvnDhws8++wze5OAvPhu0zi0tLTQazdfX18fHJzY2NiIioqWlpaKiory8PCMjIyYmJjIy0sPDw9vbGwKSvHjx4smTJ5Ab3AdpZGSkq6sL5sjwvbu7+/Xr12HHCpe7Q1kouhg6NDQ0NNTT08vJyYmNjRWNRr/HcRz0OJAb3I9aUlJSWFgIJ+vJyclZWVlWVlY2NjZvfIXP5n/ymVQTxFTYBzgCTqYYDEZTUxPsJiCxs7Ozj49PT0/PwMAAPhq5Cs0w2G25urp6eXm1tLT09vaCHgRuVS4tLS0rKzt48ODevXvhwoa9e/fu3r2bRqO9wZ0X3PgOAWU6Ojq6urrgJtUTJ04cO3asvLy8rq7u4sWLZmZmkAncjYXjuEgkUldXP3nyJNzYBXfpgD6lr6+PxWIpKyuvWbOmv7+/u7s7Pz8/Ozsb9D6wm5BDe/Gx2EdNTU1NTa2+vr60tLS7u7uvry8zM7O8vBxuxSktLS0vL3d2dra3t4c3DUQXg9PrkydPnjp1Cvqnt7e3vb0dpODw8PAnT550dHR0dnbCzSVQOjHmt5qamrq6OuTZ0dHR09PD4/GQoTPETgPbjpycHCT7QA1hNnZ1dTEYjDe+wmfzP/lMqgliijsvLperoaFx9OhRJpPZ2NjY2dnZ2dkJE8XR0dHFxWVoaGh4eBisflCkURzHIyMjY2JiYCbBXBwYGOBwOHfu3Hnw4EFJSUlRUdG+ffuOHTsGBmPgaVFUVPQGd16wk3ry5ElUVBSdTu/q6qqurqbT6ceOHTt+/Dh4WlpaWoJWQiwWu7q6op3myZMnT548CYGv4B5huA+ey+X29/evWbNm+fLl3d3d7e3tEB0CbJ0n7iP6+yHJPlpaWlpaWhCWDO4UAiWLqqrq4cOHKyoqXr58CTspOp1Oo9ESExMTEhJgt3j48OETJ07QaDQmkwk6YB8fH19fX4jF097e3tzczOVyh4eHoXQ4E0R9dezYMTqd3tDQABG1iWZW6G5uHMdzc3NLSkqKi/9fe1f61FSWt21ta2ra6pr5H6amqj9N92hbtqPjLiAIrbI44tIquAJh3ywV2ZewqOwgW4SAKLvYCInKGhgCaKMsQpBWAdkU2cKS3PN+eIpT10SW5G0SdfJ8oMLN3c7NOc89y+/3POKampre3t4XL15wOJyzZ8/Cg0TrLfxT4IUvln3gssLn8/Py8nJycrKysoRCYVFREepuWVkZnZkmhMjlcjj8oib19PQMDAxkZ2dnZWVlZ2dnZ2fX1dVVVVXBl+bOnTsFBQXv378fGBiQy+UzMzOmpqb79u1rb29XL8tUVcw361xbW3vnzh0YnObk5HR3dyMIpa2traioiK7U4NjY2Njo6GiU/e7duyUlJXw+H438zp07MOEBT5WVlT18+BAZJ1AyA/tQ3ysNQJl9hEKhQCDg8/koL5/Pn5ycHBgYwLpeVVWVQCDAsdB+u3//Pl1xz8nJycvLy87OTk9Pz8/Pz8vLgwI8dAiLioqys7Mxl4z96ciLEALZINSK4uLizMzM6enp4eFhfPv8+fOOjg5CyOzsbG1tbUVFBXzc4SsNJVw4rxYWFv7666+fC00sEz6LO1d/1hkrF/n5+XitFRQUEEJmZ2ch70KD7smHY/vXr193d3ejHeJAxG5ghig7OzszM3NwcJA6gpmbm1tYWGi379PY2NjQ0IA1Zj6fD7X5V69edXZ2vnjxAhne7GB/5LVhIqOkpARNDuao6enpmMvAzuXl5aWlpTMzM1NTU4j3WbFixcqVK7W75iUUCh89enTnzp38/Pzs7Ozc3Nzh4eF37941NTU9ffoUNn6YFG9paXnx4kVRUZFAIAAL5ObmZmRk4Jx5eXklJSWNjY11dXVgH1BST08P/EUZhmF7vSGGAxWDx+NlZ2ez/b8kEolEIsGeNTU1WBil8T4FBQVYysjMzKTrbv8LLLMAPv0SqR9tSL9S8IdROJAQEh0dzeVysYVtC0fTlwkhUqlUIQ8DCagHDhz4+eeftRttKFcyFCXkg7RYBW+shIQEmj1AD2QnNNK5DMpZDMM8fPjw0aNHK1asWLVqFZw/l7uwwHx5XjQFZIGIGMw6379/n6550aPIXN1gv4fInD8qXYJgj7wUQLPS6Znp7dXX1yOMCLPa893h/ybpUHz6RVOTfRR+b+V0RHYqKYLfMZJSPpawUr0UcsQIIfv37zc1NdXumhfdzhYSYd+wwmeqLkbXvOi3yj0a+jQo+3z11VdSqVSLfR9l0Ow2hbwtzGdBz1D+oSEXfZKElbtHHxHN6aN+XswclK/CVtvAh6qqqrq6OuSaYgvb/4sy4P8a3Sjg0y/pkthHJpNZW1tDXYyt77NEUH0f8qHn33xgq/yYmZnt37//yZMnmun7UGzdunXjxo2Dg4NwUlYJqpYX+1D2WblyJTyp1bx1VSCXy/Pz87Oysv7yl7+sWbNmPvahYHMKIQR5M5BJpRtBIguXmr6loEZCVJE3lX9MXWwpwF0FBQUFBAT8+OOP69evX/qxnyk+Zeohi7IPwuEJIefOnTt16lRNTQ1i6lUC9SZndxmW8m6XyWTm5uYmJiYtLS0ayDKlfMEwzJYtWwwMDDo7O9XQNlSjvMgeKC8vX7lyJeJ9YGGuAWRlZRUVFa1evfrbb78lS8s8oPtgLgZR70u/Iu0czczMRERERERELHpRBUYTi8X19fWNjY2NjY3YIl+yriuXy/X391+/fv0//vEP5kvPcf+82Yf+NlZWVsePH6+qqlJPWTUmJoYs+f2GGR+FTAsNzDqzh1SI1h8eHqZOykuHquWF1yBinWm0oQZUr3AJTIf/9a9/XbNmzaIXZQ+gGIaBiU1xcXFJSQmbatmKKwuchxACXWeiimGkXC5H5h3mnpfef8ELwNvbOyQk5Pvvv6d9H41NsWkenzf70NpmZWV1/vx55Ompeo2wsLD4+Hi2jOFShhV4L6Hv09zcrLEVd9zk1q1bMe/T1dWl6knUK29FRYVQKFy1atXKlSuxfqTG/auKmZmZ3NzcvLy8r7/++ttvv124I8BmZ+D58+fPnz+HY4RKoxiaPxEREYE5QZX6IJjxEYvFYrFY+SYXPhYjL7APW+Dti8TnzT70ZXjmzBlra2sXFxcHB4drKsLU1NTMzAwKvtFzWGD/qKgoLpcbGxsbHh6+du3aH3744dmzZxqYdWbrpW3ZsmXXrl2+vr4hISHLXd7r169HREQgZ2XVqlUrVqxgWPqQywf8uFlZWQUFBWvWrPnmm28WLhfikiMjIyHDFBkZ6eHh4eXlZWNjc/Lkybi4OAw58QtC2Gi+3xeIjIzct2+fubn5tWvXYmNjF32wuG5MTIydnZ2rq6u7uzuHw4mJiaHKUNeuXcMNfBRXr14NDQ01MTExNjb+4Ycf4KRMVJly+uzwebMPhbW19fHjx8+fP3/+/PlIFXHw4EFzc3NkfoeFheF1h3o8H8LDw+Pi4q5du4Za8vjxYw1kWrDlUzHy8vHx8fb21kB5o6KiOByOvb09Mi0QTb7c5UVfBkE933zzzZ/+9CdknM93k/gqJiYGw6Xo6GhPT08vLy8Oh3Pq1KnExETsA54CPc1X2IiICKiymZmZHTp06OrVqxB4XuC6UVFR+BAbG2tnZ+fi4uLm5sbhcOApiFsCo80HEBBWUdetWwd1Md28jxaxJPaZnZ21srJycHC4f/8+RtoqAVld7BAh+uGjwLdQ6kDOF1uParmB6rht27YdO3Ygz2C5y4sdYOO3evXq1atXT0xMaGYygmGY27dv37lzx93dneapzXeTNPaHmRuPQ6GxpKSkpKQEChsKJ58P9DxwJWXmltI+CvaMMo6tra2tra2tr69HlinDGj3JWfrzyg+ZYRh/f/8rV67885//hKq8Bh6yFvF5sw9tQoj3KS8vFwqFql6DRhvSFrXor06vC4PjtrY2quCxfGD3wDdv3rxr166urq7+/n5Vz6NGeRmGKS8vR6YF3AQ1EO+Du8rOzs7Ly/Pw8HB3d1/igfRBYd4H0d5sgljK4TTTAtlbSyECyiAIdFbQdV4UuKKfn19wcDAy7Igqi2WfIz5v9gGYjyls0BcgrRPYrhBSyDBMeHh4QkICXbwnrGZJ2xgNF2a/qQgh0NbTur6PQhkZlv0GDXGm39J1HKIUZMhWpCcfxmRSPy8Nq8ojs8HDw8PDwwNbFBzZaOgAO/gYv9Hz588lEsm9e/fwTqJB6uRD2zIK5aaOgRW7FuGRKgjL01Ph3mi0IbxM2eend04jJGlvC9sDAgKCgoLWrl27bt26L5h3gKWzT6U2oA770Khl+i11RKG1hN2PiIyMROYBbavsb5V77PS0hBALCws46tDIjmXFR9mH7YhAWNSpvJKFrzDFMN+EAmiFrohR2oJP7KfAPsyH69DsyXj6QT7nqPPbb78JBILi4mL8uNQ8h56f/fQUBm4Mw0SyVOgUoqLwmaqsMXM5PTKZrK6uDmLbiDZUGHkRFg2xv/oi2Wfh5s1mH80QikpQ38+LmRu90xrzUUsmOOrAzwvbaSgzfR3RSkAXYul2Y2NjExOTp0+ftrW1/VE/2MIlJfNoGyoXjRAC4U52IhjDMFh2oYfQ8iofzu5MPXz4UCgUUlV5jWkbKrMPUXLmUshQI3OkIJFIXrx4UVxc/Ouvv9JjKUfIWXZas7OzCs+BmcsBZCuxKVyFfUI2KufEfbDirjzFRj40iVu47/MZcZCqzfsLZB+6nf0qY3cE8D6nPypbRWFqaop9FLawB2sMKzeKEGJqaqp1Rx32KEDhPtkveXos1fQkLEZWHruxE0o+KfZRaPzyOSh8y8yxkgkFAAATbklEQVT5uAsEgtLSUoVGPh/YSVvyD/28CCupVeGFRAihEZgymaypqYnO+9CeGr1J+YcmgvTkn3vfR43mrRn2UbtEaipsjI6OxsXFRUZGpqen37p1Cz88VqYiIiJCQ0NTUlIyMjLoSAQzi1NTU+Pj46Ojo35+fn5+fuXl5exbZxims7Ozo6MjNjY2KysL1Q55XtCRUbuQS8dH2Qd6NDdu3Lh58+aNGzeSk5Oxc05Ozu3bt+Pj42NiYoaHh8fGxlDe0NDQyDlFkWfPnonF4tTU1JSUlJGRkenp6ba2ttevX/v4+Pj6+lZVVVVWVtI8rwcPHtBMCy2yT0dHR1tbG5bA8/PzqVMghCgbGxubm5vRqjs7O+HjXlxcTOY8Eaurqy9evBgQEPD06dPOzs6xsTGpVJqcnJyUlJSWlpaeng6moH2fqKgovKvS55CYmNjV1dXZ2fn69euhoaFLly5dvHiRxnwxDFNVVYWpn5qaGugZ5uTk8Pn82NhYqEoSQjAehKsXROw+cfZZDkZQddb5j72HRaHmyIthmOvXryckJGRlZWVlZRFCpFJpR0dHR0cHYkl5PF5KSgr6vVevXkUmISFkZGRkYGDA19c3ICCAamvRdxqcm5KSkhISEnBdU1NTU1PTp0+fajHHXSKRvHr16saNGzwe7+bNmxkZGRhwITs8Pj4+ISEB6tQ4SVxcXExMDJioqampqamJx+PFxsZC77Gnp6e7u9vX19fb27usrOzBgwdQa/t02Ke1tVUikURGRkZHRxcXFxcWFqJLMjIyMjw8/Ntvv8HviGEYZJkKBIL79++juyESiSoqKoKDgy9dutTV1SWRSCYnJ9++fcvj8dLS0sDg9NJQLIyNjcWzgjZYdHR0SkpKR0dHV1cX1KDgZvH48WO6wlVeXl5XV9fQ0CASifr7+3t7e0FbMTExkZGRGDAKhcKHDx8i+Ki/v//NmzefGvtooHl/gSOvurq6ysrKrKwsHo/H4/H4fH58fHxSUhLW4+G5zu7xIhoVNSw+Pj49PR2ZEy4uLjY2No8fP25ubobClo+Pj4uLi6Wl5YkTJ1Az4OiiXT+vvLy8zMzMd+/ejY2NOTk5eXh4QLE4JCQkICDg5cuXEokEqqA4lsvlQtuQYZjk5OSbN2/W1NS0trba2NjY2dlt2LDhX//6V19f38DAAJfLDQsLg2ceHHXAPpr081Jmn7S0NB6PB21pKMZiu4+PD5fLxQo9HlRbW5tEIikqKnrw4MHMzMzY2FhmZmZqampPT8/79++DgoIiIiKCgoJCQkJ+//33lpYW+KBKJJKuri6cASvuDQ0N1dXVhw8fPnTokFQqHR0d9fLyCgwM/Omnn3bs2DEwMNDT05OWlpadnd3f39/f3//kyZPKykp4gSCe882bN+gl+fj4ZGZmpqen+/r6+vj4wD9j586d27dv1y77aKV5f4HsU1VVVV9fD5U/Ho+XmpqamJh448YNqN41NDQgJ4uu6UBVHv/euHEjMTER7IPcgidPnojFYvhMenp6enp6Hj9+3NLSEtc9cODAvn37mpubtdj3gTIhxozwI+3u7u7p6QkNDQ0PD4cIMfSbyZx7cmRkJPoCiYmJiYmJLS0tjY2NDg4OdnZ2mzdv3rJly+DgYF9fH5fL9fX1HRoaGhsbg9vUp8A+6EdIpdKJiYkrV65Ar5phmKCgIG9v77t371L2gZtgaWkpVbNMTU3l8/nDw8MDAwPQePT39/f398eY2tHR0cnJCT0aXAtrXmKxuLa21tLS8uTJk+/evZucnPTz87t8+fLWrVs3bdrU29vb29ubkZGRnJw8Ojo6NDQEb+v6+vra2lqoaA8ODg4NDXl5eV28eDE7OzstLS0gIMDHx+f9+/dTU1Pbtm1bOvtou0n+kfiUqafy/zPrDCV5a2tra2vr/Pz8/Pz8+Pj469evY5R++vTp06dPMwwzNTUF90t6KoZhmpqaxGKxmZmZubm5RCJ5/vx5UlJSTEzMo0ePhELh0aNHjx8/DrY6cOCAqalpc3OzdrUNZTIZFI7BjOxowKCgIC6X6+Li4urqSgiRy+VICKBrgrOzs5cuXcJrOTQ0FB4e7e3tzc3NBw8exNlmZ2cFAgFbXUyLK+4AVu5cXFzs7e0xR/7q1atXr17l5ORQHeuOjo729naoyuP36u/vf/funa2tLYfDyczM5PF4bNeKCxcuXLhwAfq52IKsCywaDg4ODg8Pp6SkpKWlhYaGXr9+/fDhw8ePH6+urhYIBB4eHs7Ozv39/QMDA1hxr6+vr6+vn5iYkEqlra2tzc3N+HXg7H758uXLly/Dx/3w4cO//PLLfOyj7Ta4jPgC2QdvdTgxnDt37uTJk1hzjYuLi46Oxtvy7Nmz586dk0qlU1NT4eHhNN4Hf6HMglgezBbFxcUlJSWhY3Xs2LEjR47g0p+Cjzu+ys3NzcrKAjOixtPYWT8/P/j8Yk/2Og5W9FxdXT09PSMiIry8vN6+fQuF9o6ODktLSwsLC3jsYA4I7KNJXWdl9kFcaHR0NHzc3d3dIbMNq+K8vLy8vDwyN+8DN8HS0lIci/nd8+fPu7m5JScnZ2ZmRs4pN8vlck9PzytXrmRmZt66dQtzSej7QIC1r69vdHQ0Pj6ez+fDvQt+ROXl5TU1NZ6enq6urm/fvu3r64O0mEgkEolE09PT8DJtb28/dOjQkSNHhoaGtN2sPmNoptYB6rCPSCSqqal5+PChSCSC71JYWFhwcHBbW1trayv6xhcvXvTw8KioqKisrES+KCFEJpNhzWhwcLC/vx8zmtXV1TU1Na6uri4uLo6OjhwOZ8OGDRs3bpycnJyent63bx+8TLXIPhkZGYWFhcPDw8PDw4GBgV5eXmlpaRkZGZmZmXw+H/xy+fJlX19fBLnQvh7DMKmpqTweb3p6WiqVent7+/r6woMYPUS4nqHXQLUNkWmhxZEXn8/n8/nINYOmJfSboaUPRQ7sCSfl+/fvl5aWgo4zMjL4fD4hRCaT7dq1a+PGjf7+/oGBgSMjI+Pj42FhYf7+/j09PVS3BHleeJ/Bk+vu3bvUmxCugZhLsrS0PHPmTG9v79DQEOZ9dGBDM7Xlj4U67ANVJzjAvHnzpq+vD7IJbW1tXV1dExMT4+PjFy5cAPuIRKKIiIi4uDjMOqekpPB4PPjqlZWVFRQUVFZWVlVVOTo6uru7u7m5OTo6rl+/fuPGjegRINNCu/M+BQUFmZmZs7Oz4+PjXl5eXl5eGRkZPB4PM8oMw4yPj4OVwCPXrl0LDQ3FCZOSkpKTkzFnFBwc7OPjA2MMLy8vb2/vgYGB4eFhXBSzZp8C+2AxgRAyMTFx5swZKysrrIK9fPmyq6srJyenoKAA9wxd53v37hUXF6PseDKEkNnZ2c2bN2/bti0wMDA4OHhiYuLt27dXr14NCQnp7u7u7u4GU0dGRiYkJKCjd+rUqV9++QXOFrgTuIncunUrIyPjxIkTx44dGxkZGR0dramp0XZj1wI0Ux80CTX9vEZGRnx8fC5duuTt7e3n5weFTby9/fz8YPIdGBhICJmensb7DbWzsbGxvr6ey+ViwhVOytSz6dmzZxKJhMfjofXK5XJTU1MLC4tnz55pMdNCJBKJxWIfH5/AwMCAgIDg4GCEUyYkJISFhYWEhAQGBsLLHBEG0ILAvE9SUlJWVpa/v394eHhVVZVQKAwICOByudCyiI6ODgsLoyMvOOpofeRVVFRUVFREtUEQjzMzMzM4OPj+/fumpqaGhgbELre0tHR2dkJdDOsG0BW5evVqfHw8ZgNFIlFdXZ2fn5+/v39BQQH6NcxcsgXmjF+9etXT04PZsYiIiKioKHhyIU4qLCwsJibm5s2b6enphBCpVIpV1y8AmvmJP1mowz5jY2NjY2MBAQEXL16EAk57e/vLly8rKirq6uqCg4P9/f1DQkL8/f1Rydhepo8fP25qaoLOE1qyVCrFtIJUKkWMWUxMTFJSEtjKxMQEmRbt7e3L9hA+KClRYh/oOXC53JCQEF9fX1ouLpcLIbSoqKiysjIacRceHh4dHY1ZIcQlcLncoKAgjEOxEoyGHRYWFh0djXgfgUBA2Ue7fZ/bt28XFBQgUiYhIYHG7w0NDfX29v73v/+lOpPwOy0uLkasMyEkLi4OL5uwsLCCgoLi4uLy8nKxWOzn5xcUFITIIHYsNTItfv/9d4lEcuXKFXd3d6xd5Obm3r17NyUl5ebNm8jaTU5OTk1NxVFYdRWLxSKRCMqw/v7+AQEBqGn19fULtHY1Vtx1PLJMUHPNiyZSsFMH0JemVk3YPjMzw+Vy4+Li2JnT7Bf77OwsO1NMYQdzc3O496qkpaA25pt1Zrvi0Pc23T45OUkfCCEEfR+ilFWrkEOAVS0aGPXo0aNPZOTFvmGGYRTSYslcVo1UKm1ra0PfB8zLMIxC5q1CUjF4Fp/hFg1PCzYLKOR5AOxMV8Q6V1dXi0Six48f07yKRdlBpXgfXedFA1B/zYv9yynkc9MahsZJMwmV1afYn+m/7Kr2888/Y96ntbVV5cKpjgXWvMiHOUpEiU3oGTALppD6yGYu8jGtiQcPHtBZZ+2OvNhZXcpgf9XZ2dna2nrv3j2BQMAuEXsf5bOxCw7VQeVsLMJiLoaVSEgjqhFqCDfBhdlBQX1hibSiYxwNYEmq8oSQEydO2NjYlJWVVVRUqHqNax+66xGlFqsAdmU1MzODl6kmZ50JIZs2bdq5c2d3d7cajjqqlpcQIpPJKioqBAIB2GdmZkZj8T6I33F1db106dLCgors4uDzs2fPOjs7S0pKkAumLFowH6jCASa/Ft5ZmdRqamqwHPb/pxId42gRS9U2tLa2PnXqVGVlpUAgUPUaiL6j/7K7OQtcFy3BwMAAIy+NqcojDgV9n56eHvUcdVQqL4hGKBRWV1fDSXliYkIDboIoL5zaL1y4AG3DBW71o+zT3t4ON0GFMy9RLzk8PBz94iXanBBC5HI5skx1dPO5Y/GRF+Zlzp49e+LECSy3q3oNWsOApbAPIJPJ/vOf/1hYWIjFYs3E+9DZFnhavHz5kj3yWiLUKC/DMMjzQt+HEDI+Pq7qddWATCYrLCy8ffu2h4eHp6fnovoYCkC0YWlpaVlZ2czMDITiFhi1AXjIWCOD28fCVKU8SoWis9rM4ufnt3bt2vXr15PPStzny8NSPS2srKzOnj0rFArVcBOMjY2lOe5LBK3ERkZGpqamLS0tmlHYIHM6PohV6evrU2PkpUZ5CSFlZWVVVVVfffXV119/LZPJNOBpgZLy+fzCwkI3NzdkiixABPIPIZPJJBJJZ2dncXGxUChUmKhalIOAmJgYrOgvZX9cVyqVItxMvf4LcmW///57OOosPMmlw7JicfaZnp6enZ09f/78yZMnkRlgryK2b9++YcMGDw8PDodja2tra2vr6Ojo6Og43/6Oc7Cxsfnuu+/+/ve/NzQ0aMxRhxAyMzOjp6e3cePGEydOWFlZLXd5kZdgamq6f/9+9H3GxsY05uNeWFjI5/N/+umntWvXOjs7Ozg4zHefLi4uzs7OTk5OTk5Ozs7Ozs7OR48ePXLkCLJhcCyKbG9vv8B5bG1tnZycbGxsHBwctm/fvnnzZmdn5wWeJ56hg4ODg4MDYuLNzc2xGGppaens7IwoeXt7ezs7Ozs7u/nOgxq1ZcuWzZs3//jjjxs2bNBRj3axVCflY8eOnT59et++fQcPHnRQETt27NixYweHw3FycnJ1dXV2dkY9mG9/GxsbVCYOh/Pdd9/97W9/a25u1oyTMp2w2Llz586dO8+dOwcroWUtr5ubm62t7cGDBw8cOLBixYo///nPExMTGvCZwlgpNze3sLAQrRGtdIGiwXQMf+3t7ZGHYWxsvH//fhQQHOTk5LTAeZC5ir///ve/t2zZ4uTkBKPKj8LJyQl/wSx2dnaHDh2ytLQ8fPjw0aNHkdHK4XDYO38Utra2Li4umzZtgpnXunXrqJLvcj9qHT6Kxfs+aAZYm9i7d6+ent4eFbF371580NPT2717t56e3t69e42Njefb38jIyMjIyMDAYM+ePdbW1kePHpVKpVS7SzNISUlJSkrS09MzMjJa7vLq6emZmJjs3r17z549bm5u9vb28g91+5cVvb29L1++3L9//4EDB/bs2WNoaDjffeIrPBBDQ0NDQ0M9PT2UzsDAwMTEBDss+tAMDAx2796tr69vZGSEaFJDQ8Ndu3YtfIiRkZG+vr6hoaGRkdHOnTv19fX19fX19PRwJ7gl1Jn5gIeMiyYnJ8fHxxNCJicnNdPN1EEZS533gV4qbVcqYffu3cbGxrt27aK0snBFoV8ZGRlZW1ufPn36/fv3o6Ojy/ogACw/MQyTnp7O5/ONjY3VYFtVy4t2pa+vb2xsbG9v7+npqbERgUwmGxgY6OvrMzMzs7Cw0NfXX7hoYAHl7eCFPXv2GBoaglYWOBVoy8TEBDRkYGCgr6+/QNXC06NvPpzc2Nh47969RkZGlH3oG2s+6OvrG8yBrcGqg7awVPbRQQcddPhjsXi0oQ46fPHQTGPTQQG6vo8OOuigHej6PjrooOv7aAe6vo8OOuigHejYRwcddNAOFmGfcR10+B+AZhqbDgpYhH3GdNDhfwCaaWw6KOD/AF9ZaGyZgGxwAAAAAElFTkSuQmCC)
![](https://www.clublexus.com/forums/data:image/png;base64,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)
My test showed that knock sensor 2(pin 2 and 20) was showing totally different reading consistantly then Knock sensor 1(pin 1 and 28), even when I knocked on the engine with a hammer (Gently).
Now after confirming that the problem is a BAD knock sensor since reading is not changing even when I knocked on the engine, instead of disassembling half of my engine to replace it, I just cut the wire of pin 2 (RED) and connected it to pin 1 (Black) on ECU side and cut pin 20(green) and connected it to Pin 28 (White) on ECU side. IT's plug E9 in the picture.
No more check engine light with error code PO330.
Please do it at your own risk, I am not responsible if you damage anything while attempting this.
I'm trying to access the ECU behind the glove compartment to get a good view of the cable connections. I am getting a knock sensor code and wanted to check the connection and wiring on the ECU. What else besides the glove compartment do I need to remove?
sonyoor
05-12-14 07:03 AM
sirgabo
01-30-14 08:33 AM
canucklehe
04-27-13 12:38 PM
