Headlights!
2nd gear
Hey all, new to these forums, not to cars. My mother owns an 05 RX330 and has a front passenger side headlight bulb out. The stealership wants to charge just over $600 to replace this bulb. Obviously, I wont let her get ripped off like that. The question is, should I just replace the housing? Or are the bulbs relatively easy to replace? I have never worked on a lexus before, and know these headlights have a bit more to them than the ones in my 06 Mustang. Any help would be great!
You can buy the bulb on Amazon for around $50 and install it yourself. There's not much space to work with so unless you have small hands, it can be a little difficult to Install the bulb. Or take it to a independent mechanic and have them install it. Shouldn't be more than 30 bucks.
Just remove the headlight cover turning it 1/4 inch then pry it straight out with a flathead screwdriver. Then you will able to access the bulb. you can do a search on this forum to find more detailed instructions
HustleHard
SC- 1st Gen (1992-2000)
12-25-05 01:32 PM
