Reverse Mirror tilt stopped working after battery change
2007 RX350
Change the battery and now the two side rear view mirrors will not tilt when put in reverse. They used to, but not now. Is there a setting or "reset" I need to do somewhere, like with the windows etc.?
Yep, I did. I just went out and tried to re-do the seat settings (with the mirror switch in the middle) and it still won't work.
All I did was R&R the battery. Everything else I have gotten reset (windows, moonroof, clock, seats, etc.). I've changed the battery before and don't remember having this issue.
??? disconnect the battery and try it all again?????
Solved!
OK, I was reading about this and read where someone said the Mirror L/R switch had to be in the middle for the auto-tilt to work. But, then someone said that his had to be in either L or R and NOT Middle for his to work
Well, I went out and guess what . . . . . . If the switch is in the Middle the mirrors DO NOT TILT. But, if it is either L or R, then the mirrors DO tilt.
Go figure?????
Go figure?????
LexusLadi
03-21-16 10:33 AM
