parking Brake warning Light
Had that happen with my RX350.
The sensor switch that is mounted on the pedal assembly had come loose, rotated, and was not being pushed properly. I had to go through some unpleasant disassembly of the dash to get to it. You'd think that, with just a couple of bolts, the pedal assembly would come off. But noooo.......
The switch was put back in place, well-taped in position, and everything is fine. I really don't want to take the dash apart again and you will likely find the same.
See this thread. Don't know your model so it may not apply.
https://www.clublexus.com/forums/rx-...light-off.html
