Rear wheel hum - Rear bearings at fault?
Hi all,
I suspect my rear left bearing is up for a change as it hums when i drive. Sometimes when i take a bend, i can hear a light thumping noise from the rear end.
I didnt see any threads on DIY bearing change for 2004 rx330. Any one of you have done a bearing change?
Thanks
Thanks
I had a similar problem with my 2006 RX400h early this year, only mine was from the right side, when I set off and got up to 60mph there would be the most god awful noise which sounded like the wheel was about to break off, but when I went around a corner there would be a big thump and the car would run normally. Also at low speed I could here the brake screeching at the rear even though my foot wasn't on the brake. Got new brakes all around which half solved the problem but the noise from the rear right wheel was still there. Returned it to my garage (independent) who adjusted the brakes, re balanced the wheels and put now rear tyres on as the old ones were done for, finally they did the tracking as well. In which they broke the AFS sensor so my headlights wouldn't swivel around any more
had to pay to fix that as well.. Although happily it did solve the problem and I have had no other problems with the car since then. Surprisingly despite it having a lot of work done it wasn't to expensive, but obviously we didnt really discover the root cause as it appears it was a plethora of problems. My guess would be an issue with the parking brake, which I have been told doesn't need to be on all the time, just on a steep incline etc. as the car will hold it in park, but I still use it all the time anyway as the last thing I would is my Lexus in my living room... If the noise is constant then its likely to be a wheel bearing as my other car just needed a new one done, but that made a higher pitched humming sound. So basically, good luck, or hopefully its better than mine was anyway
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
had to pay to fix that as well.. Although happily it did solve the problem and I have had no other problems with the car since then. Surprisingly despite it having a lot of work done it wasn't to expensive, but obviously we didnt really discover the root cause as it appears it was a plethora of problems. My guess would be an issue with the parking brake, which I have been told doesn't need to be on all the time, just on a steep incline etc. as the car will hold it in park, but I still use it all the time anyway as the last thing I would is my Lexus in my living room... If the noise is constant then its likely to be a wheel bearing as my other car just needed a new one done, but that made a higher pitched humming sound. So basically, good luck, or hopefully its better than mine was anyway ![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
I did just replace my rear wheel bearings...definitely worn and needed to be replaced. There is some info in this thread......
https://www.clublexus.com/forums/rx-...l-bearing.html
