2005 RX330 Aftermarket Stereo Installation
Hello,
I recently installed an aftermarket stereo in my 2005 RX330 (no navigation, no Mark Levinson). I left the OEM amp and speakers in place, using the Metra Axxess interfaces to connect to the OEM amp and steering wheel controls. I also installed a rear camera using a wireless transmitter/receiver combination instead of running a video cable from the rear hatch. There were a number of posts with pieces of information on how to perform this install but nothing comprehensive. I documented my experience in hopes it will help someone. The document includes pictures and detailed instructions.
Aftermarket Radio Replacement v3.pdf
I am still pleased with my installation. As I said in my write-up, my main objective was to get some modern features:
- The Bluetooth works great. Not only do I use it for hands-free calling, I figured out that I can stream music with it as well.
- The GPS works even better than when the unit was installed in my LS430. In the LS430, every now and then I would lose the satellite signals and the GPS would stop working until they returned. In the RX330 the satellite signals are always very strong and I have never lost them.
- The USB connections work very well. When I plug an iPod/iPhone into it I can control the music using the unit's touch screen. I can also plug in a USB device with music on it.
- The back-up camera works - it is very clear during the day but it is not as clear at night. I bought a fairly cheap camera so I guess I got what I paid for! I am not too worried about it because I do not use it as much as I thought I would. I think a set of proximity sensors would be more useful but I don't plan to take on that task.
StanMotion (08-16-20)
I said that I would report back once I installed the Y-cable on the 2 diversity antennas to see if my reception improved and it has. In addition to the Y-cable, I had to purchase an adapter for the smaller antenna connection so that it would fit into the Y-cable.
I updated my attachment as there were a few things that I learned/implemented since the original post:
- I updated the paragraph about the radio antenna. I also added the Y-cable and adapter to the parts list in the beginning of the document and I included a picture of them.
- I changed how the rear camera wireless receiver was connected. In the original installation, I connected the receiver's power and ground to the same harness group as the TYTO-01 and steering wheel controls. However, I decided that I would power it from inside the car - it seemed cleaner that way.
- I ended up soldering the radio wires to the TYTO-01. In the original installation, I used crimp connectors on the wires. This seemed to work fine initially, but after a while I started getting intermittent sound from some of the speakers. Several radio installation articles I read strongly suggested soldering the wires for improved audio quality but I was not as concerned about that. However, the crimp connectors were not making reliable contact so I cut them out, soldered the wires and put shrink wrap on them. I purchased a small butane shrink wrap torch and shrink wrap sleeves for about $20 at Home Depot. I am now a believer - solder your radio connections!!! I left the splices and spade connections in place in other areas of the installation as they appeared to be solid; it was just the crimp connectors on the radio wires that were faulty.
First of all, thanks a ton for the pdf, it has been really helpful. I have a 2008 RX 350 and have a couple of questions. You mention using the 12pin for the ASWC-1 connections but in the ASWC directions it talks about using the 20 pin for connections. Is it a typo, or did you definitely use the 12 pin? I can't seem to get mine to work or even power up. Also, I'm wondering if the cable colors are a little different for my car in regards to the reverse light. I think I'm going to have to get a circuit tester to figure out where exactly my reverse light is. Thanks again!
Bgreet,
Thanks for catching my mistake. The connector from the OEM unit that contains the steering wheel controls has 20 pins, not 12 pins. I confused it with the 12-pin harness on the ASWC-1.
You mentioned that you cannot get your unit to power up. I assume that you have connected the ASWC-1's power wire to the car's accessory power and you have attached the ASWC-1's ground wire to a ground source. I tapped into my radio's accessory power wire to power the ASWC-1. The Metra instructions recommended attaching the ASWC-1's ground wire to the car chassis (which is what I did) instead of the radio ground. I assume that this was to ensure that the unit did not cause any interference with the radio. Even if you attached it to the radio ground, I would expect it to still power up OK. If you continue to have trouble, I suggest that you send Metra's technical service department an e-mail. When I was having trouble with their TYTO-1 radio interface unit I sent them an e-mail and they responded to me very quickly (within a day).
Unfortunately, I cannot help with finding your reverse wire since your model (2008 RX350) is different from mine. You may have to find it using a meter as you said.
Good luck!
Good luck!
The following 2 users liked this post by Oldsports:
bgreet (03-22-17),
Thanks for the quick reply! Yea, I'm not sure what is wrong (new radio works perfectly fine). Metra has a harness that they sell on amazon for $10 that allows for directly connecting the ASWC in... we'll see. Also, just an FYI I had the same issues with having to resize the metra dash replacement to get my double din. Thanks again for all the incredible help! Would definitely not have taken on this project had I not discovered it
Bgreet,
I just updated my PDF to correct the mistake on the 20-pin connector. Thanks again for pointing that out.
I wish I had known about the ASWC-1 adapter harness when I installed my unit. I assume that would have saved me from having to tap into the wires on the 20-pin connector. I am interested in how it works if you decide to use it.
Thanks!
Thanks!
After putting it in today, the harness is well worth the investment in my opinion. Everything powers up now and goes through the standard LED cycling, ultimately going solid red on the ASWC. Unfortunately, still can't get the actual controls to work.... wondering if it's an issue with the ASWC choosing the wrong head unit type (I'm using a BOSS). I'll play around more with it this week
Hi...thanks for sharing this useful information with us. Sure it is gonna to be very helpful for all. I want to know using the 12pin for the ASWC-1 connections but in the ASWC directions it talks about using the 20 pin for connections. Is it a typo, or did you definitely use the 12 pin?
Hi RickyTerzi,
Yes, the correct harness has 20 pins, not 12 pins. I made this mistake in my original write up and updated it. Unfortunately, it looks like I did not correct all of the references to the 12-pin harness. I will make the corrections - again! Thanks for pointing this out.
