Backup camera
Old 12-02-16, 05:21 AM
vegerad
vegerad's Avatar
Default Backup camera
I installed a backup camera on my wife's 2009 RX350. To avoid tearing apart the interior I used a wireless system to get the signal to the screen. Problem is I need power somewhere in the front of the car that is coming from the backup lights (so that the monitor turns on when the car is in reverse). When the screen is powered and has no signal it constantly blinks. Trying to guess which wire under the dash is going to the back up lights isn't an option, and running a line from the back kind of defeats the wireless option.
Old 12-02-16, 06:41 AM
vegerad
vegerad's Avatar
Rereading the post I realize I didn't make my question clear; anyone know where the wire powering the backup lights is in the front dash area?
Old 12-02-16, 08:20 AM
Lexuswiz
Lexuswiz's Avatar
Do you have a multimeter? Toyota/lexus usually runs wire for the rear lights from the BECU to the trunk which is behind the dash. But the easiest place to tap is the drivers side kick panel. I forgot which plug it is but I did find it when I was doing my remote start install trying to find the brake light wire. Engage the ebrake, put the key to on position (do not start), put shifter into reverse then start unplugging the plugs one by one. Once you narrow down which plug has the reverse lights, start metering the pins.
Old 12-02-16, 08:58 AM
NVAKeith
NVAKeith's Avatar
Here is reverse light wire in the loom in the cargo area. Look for a similar wire loom in the driver's footwell kick panel. Although my five years ago memory is telling me that it changes color in one of the junction blocks under the dash....so don't be surprised if it's a different color up front.
https://www.clublexus.com/forums/rx-...ml#post8421434
sbryant324 (05-05-19)
Old 12-02-16, 01:28 PM
Oldsports
Oldsports's Avatar
I don't know if the RX350's driver's side kick panel is the same as the RX330, but I recently did exactly what you did to my 2005 RX330 (installed a wireless back-up camera). I found this post that explains where the Reverse feed is in the RX330, complete with pictures:
https://www.clublexus.com/forums/rx-...ick-panel.html
The title says "Brake Light Wire" but near the end of the post it explains where to find the Reverse feed.
Hope this helps.
Old 12-27-16, 09:49 PM
BolderLexu
BolderLexu's Avatar
Hello all,
I had some plans to retrofit an OEM backup camera onto my 2008 RX350 and hook it up to my Garmin nuvi through a wireless transmitter. Is it going to be too much hassle? The harness converter which connects the camera to the transmitter seems like to be the hardest part to find.
Old 12-28-16, 11:00 AM
Lexuswiz
Lexuswiz's Avatar
Originally Posted by BolderLexu
Hello all,
This is too much hassle and exactly because what you mentioned, the OEM camera uses a non-standard plug. You're better off with an aftermarket camera, if you want it to look stock, you may need to do some fabricating otherwise those license plate cameras are easy to install.
BolderLexu (12-28-16)
Old 12-28-16, 08:17 PM
BolderLexu
BolderLexu's Avatar
I found this converter piece:
http://www.ebay.com/itm/301402764928?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Still a long way to go tough!
Old 12-29-16, 08:38 AM
Lexuswiz
Lexuswiz's Avatar
http://www.ebay.com/itm/301402764928...%3AMEBIDX%3AIT
Interesting find. My only concern with that plug is the power. Most cameras I've worked with use two wires for the power not just one green (if that even is the power). Then again the ones I work with are aftermarket not OEM, and I haven't really taken apart the OEM one on my own to car to tinker with it.
Old 05-01-19, 06:12 PM
cdmn
cdmn's Avatar
I know this is an old thread but does anyone know if I can install a factory RX330 camera system in to one that doesn't have it?
Old 05-03-19, 03:47 PM
tomr51
tomr51's Avatar
wiring is normally on all cars. have a look for a plug behind where the camera is installed.
Old 05-29-19, 09:29 AM
cdmn
cdmn's Avatar
But does the car have the capability to run the wires even though it didn't come with the camera from the factory?
Old 11-09-19, 11:14 PM
mspearl95
mspearl95's Avatar
does the oem backup camera in the rx350 have better picture quality than the one in the rx330? and are they interchangeable? backup image is very poor at night- 05 rx330.
Old 11-10-19, 04:43 AM
SpruceRain
SpruceRain's Avatar
No idea on interchangeability, but I read a russian blog post where some guy said he replaced the OEM camera on a 2006 RX (part number matches the camera on my father's RX) with an aftermarket camera, and it worked well. There's also this useful thread. All of these suggest that the camera is just a basic camera (albeit 6V rather than 12V).
EDIT: Fitted generic aftermarket camera, got power from reversing light, works well.
mspearl95 (11-11-19)
Old 11-11-19, 09:33 AM
iMSQ
iMSQ's Avatar
try to replace the bulb at back-up lamp with high-performance LED. I did it, and I'm satisfied with the image at night.
Quick Reply: Backup camera
