Oil change blues
10th Gear
Alright, so went to change the oil on my 2007 Lexus RX350 and put my horse before the cart.
1. First, I drained the oil from the pan. No problem.
2. Second, I could not get the small cap off the bottom of the oil filter cartridge holder. I used a 3/8" ratchet head and wrench. Apparently, the person before me (dealer most likely) torqued that baby down hard. It actually started to deform the "square" as I tried to turn it.
3. After that, I was like, well, I'll just unscrew the whole cartdidge holder assembly (and perhaps just be a bit messy). However, I do not have the special tool. I was just trying to use a large pair of channel pliers to get it off. Well, that previous person (again, dealer likely) torqued that baby down tight also and I didn't want to do any damage.
So there I sit, oil out of the car and unable to change the filter. So, I put back in the oil pan drain plug and filled her up with 6.5qts of synthetic.
Questions:
1. I am going to get the oil filter wrench (TOY640). When (if) I can get the oil cartridge holder off, how much oil is going to come out? Or do I have to drain the whole thing (perhaps capture the oil) and fill her up again?
I am hoping I can just remove the oil filter cartidge holder and lose a quart (and perhaps it is a bit messy). I would then see if I can get the "cap" off the oil cartidge holder. Then I would just do the filter change. Add back in a quart (or whatever I feel came out), check the dipstick, and drive until next time.
Questions:
That cartridge is stuck really tight! That little end cap has never come off on my car, either. The first time I changed the oil, the whole cartridge screwed off and i have not bothered to try and get the little pre-drain cap off. It makes removing the cartridge very convenient, no special tools needed.
I usually remove the filter before I drain the pan, so when you do get that cartridge off, you won't lose much oil, less than a quart.
FWIW, I have a 2010 Lexis IS and the cartridge doesn't have that pre-drain cap. Other than that, it is the same thing.
10th Gear
Thanks for the quick reply. I much rather prefer a cannister style oil filters vs cartidge. But oh well. At least I know I can get the thing changed next week when I have the oil filter wrench.
ToyotaLexus
Maintenance
02-17-09 01:28 PM
