Help instaling subs and amp
I want to install some subswoofers in my girlfriends Lexus. She has the 400h all stock. I do not plan to install another headunit but I do plan to put in a mother amp and subs probably just 1 10inch. Any help on where to wire the remote wire and the rca cables?
Since you will be using the stock headunit there will be no factory RCA's. You need an LOC that will tap the signal lines between the radio and amp and then that will provide your RCA output signals. Remote turn on can be found on the amp itself or any cigarette lighter/outlet nearby.
What kind of sub are you trying to install ?
xhtby21tx
03-23-11 11:24 PM
VIPnsanity
12-17-09 12:10 PM
mrshabo
14
09-09-03 12:25 PM
