2008 Lexus RX350 front bumber cover.
Hello all. New member here, trying to get some info regarding replacement of a front bumber cover for a 2008 Lexus RX 350. In planning on taking it off this weekend and replace with a new one. Any info would help, guides, instruction etc.
Thank you.
Thank you.
Welcome!
If you do a search for "headlight moisture," you should find a thread that has some info with pics about loosening the bumper, since it's needed to remove the headlights. Look for one that's marked "merged thread." It should only be a few more clips/bolts to completely remove it. This might be a good time to remove your headlights and apply a bunch of silicone around the whole lens and bottom HID ballast compartment (if equipped) to prevent future moisture/water issues, if it hasn't been done already.
EDIT: Here's the thread.
https://www.clublexus.com/forums/rx-...st-19-a-2.html
