Suspect transmission noise when early morning start up
Hi everyone,
i am a new member in the forum. I have an inquiry which you may help to advise.
when I start my RX 330 model 2004, in the morning it make some noise which suspect it is from the transmission. Another symptom is it is hard put the transmission from P to D. However after a short drive when it becomes hot, the sound disappear and the shifting gear become smooth not so hard to put from P to any for example D.
in this case, I believe to be some of the filter block problem on my own view. Need your advise whether it is right or any other matter I should look into?
thank.
thank.
Welcome.
When was the fluid changed last? If never, or you're not sure, do a drain and fill with a high quality fluid, synthetic would be best. Make sure it meets Toyota specifications - T-IV.
I've noticed a decent improvement with mine after one drain and fill with Valvoline Maxlife fluid. I'm planning to do at least two more over the next few weeks. I think mine was on the original fluid with 134,000 miles on it (over 215,000 km).
lexuscb (02-24-17)
lexuscb (02-24-17)
Hi, I am not sure on when but when I visual check the color of the oil it seems ok.
Welcome.
thank for advise. I am not sure when the oil was changed since I just bought from the previous owner. I did the visual inspection and the oil color seems ok. However I will do the oil change. I am now waiting the filter to come since I intent to change with filter also. In Cambodia, most of the mechanic say never need to change the filter for ATF. When I follow the expert view on YouTube mostly it is recommended. So filter is not available at most dealer so i did order on eBay from a shop in Australia. Lead time is around 4 weeks. On your view if I delay the oil change to another 4 weeks, any suspectioal risk/problem?
hi,
lexuscb (02-24-17)
The filter should be fine for another 4 weeks. In the meantime, I would do a drain and fill of the transmission fluid. It should take about 4 liters (4 quarts in the US) of T-IV compatible transmission fluid. You'll need a 10mm Allen wrench to remove the drain plug. Make sure it is pushed in firmly. If it hasn't been removed in a long time, it will be very tight, and you might start to strip it. That almost happened to me.
lexuscb (02-24-17)
