HD Radio
Old 04-03-17 | 10:50 PM
pauljcl's Avatar
pauljcl
Default HD Radio
Trying out a MB, I listened to HD radio. Great - particularly here in Miami where it is difficult to get classical music. I discovered the BMW had it - I 'clicked' it on .. and - yes - great!
Unfortunately my 2009 RX350 - 'normal' sound system - does not have HD radio and, as I read various posts and google results, it appears I will soon be the only remaining human to want HD radio !!). Has anyone installed - CAN one install - an adapter that gives HD radio, or must I get one the very few portable units and use an FM broadcast connector?
I have fund one that might fit - probably out of production but very few stores have very few units left - the JVC KTHDPK1. Does anyone know it? Is it any good? Can it be connected/wired to my sound system?
Is changing the entire radio/CD unit a reasonable option? How difficult would it be to install given the 'custom' Lexus look?
Thank you for any advice you can provide!
Old 04-04-17 | 12:02 AM
viffer's Avatar
viffer
Paul, HD radio is part of the stereo head unit...there are no adapters. I just installed a Pioneer 4200NEX to my 2004 RX330, which includes HD Radio, Pandora and bluetooth. I understand your excitement in regards to the HD Radio...the reception is certainly much clearer than standard radio. However, I normally just listen to Pandora or music saved on my USB or phone via bluetooth.
I made a step by step video on how I installed the aftermarket stereo, if you are interested in watching it, check out the below thread I started:
https://www.clublexus.com/forums/rx-...ight-dome.html
Old 04-04-17 | 07:52 AM
takeshi74's Avatar
takeshi74
There are certainly aftermarket HD radio receivers that can connect to factory stereo systems. PAC Audio, for example has one. However, the receiver requires a vehicle specific interface so by the time you've purchased both and any necessary harnesses you might be better off with an aftermarket stereo. I haven't carefully compared but you can certainly do your homework. Take a look at the usual aftermarket solution companies and don't overlook existing discussions.
Old 04-04-17 | 09:21 AM
pauljcl's Avatar
pauljcl
Thank you very much for the link to the video and the advice. It is too complicated for me. But I must congratulate you on the work you did. Very impressive.
Old 04-04-17 | 09:27 AM
pauljcl's Avatar
pauljcl
I think I will abandon the project. Cost and complication is too much.
I have ordered - still to receive - a small 'portable' HD radio that I can use at home and I will try it in the car - curious about reception quality. If it does work well in the car, I will just use an FM adapter (the HD radio has a 3.5mm plug output). Most of the time, I am not alone in the car and the radio is off..... Reminds me of when I was young in Europe - had a Fiat 600D and I used a portable radio fixed up above the rear-view mirror to listen to....
Again, thank you to all for your useful ad well-thought-out comments.
The nuclear option, of course, is to buy a new car.....
sears1234
09-04-12 03:25 PM
Frisco
11-26-06 06:56 PM
