RX400H New Shock Needed
Hello All,
Seems very limited. I would love to firm up the 88' Old Cutlus Supreme feel a bit. :-)
1. OEM $$$$
2. KYB - OEM "like" $$
3. Monroe - ? $
Not much on the forums either. Any advise would be apprecieated.
1. OEM $$$$
3. Monroe - ? $
If you want to firm up the ride, oem won't do it, you will have the same thing. Monroe will be pretty similar to oem.
The leaves KYB. I have used KYB on other cars and they definitely will give you a stiffer ride, You will also feel every little bump in the road.
I did the KYB Felt the difference right away. Going over speed bumps, you can tell there's a less of a bounce. I like it.
it does firm up over OEM.. well, OEM @ 100k that is. It was a pain in the butt to change but after product was worth it. Try to change the hats or whatever the top is called. I didn't but wish I did.
Literally, in the same boat as you are, back struts are shot, also feel like I'm in a boat. ![](https://www.clublexus.com/forums/images/icons/icon9.gif)
Will be going for Monroe struts, the least expensive & available struts here in the Great White North.
Besides, the wife endorsed the "Caddy" similar ride before bouncing all over the place & is willing to contribute some $$ to maintain it.
![](https://www.clublexus.com/forums/images/icons/icon7.gif)
Have a 2006 330, same issue. you get the quick struts, or just shocks?
I have a shop that will install, I just have to buy them.
Do you have part numbers and where did you buy from.
thanks
thanks
